Coolant leak question
Old Dec 7, 2011 | 09:43 PM
Roelito78's Avatar
Roelito78
Hello,
Well, I have not been on this forum in a while. My truck has been running smooth for about a month. A little while I noticed a small pool of engine coolant under the truck on the right side underneath the starter. Its dripping of the right frame area. Not sure were it could be coming from. I used a flashlight but could not verify. Its about 37 degrees outside tonight and the truck has been parked for a day. Any ideas? I checked my radiator and hoses up front and no signs of leaks. The pool is further back so this worries me a bit. Any advise is appreciated!
Old Dec 7, 2011 | 10:01 PM
mikeo0o0o0's Avatar
mikeo0o0o0
My first guess would be a core (freeze) plugs. These can be a royal pain to replace because of access. They just drive in with a hammer and socket but there's usually very limited room to work.
A second guess would be intake manifold gasket leaking at the back of the block and running down the back of the engine.
Old Dec 7, 2011 | 10:04 PM
Roelito78's Avatar
Roelito78
Mike are any of these two costly? Should I be concerned with either of these? Were are the freeze plugs located? Thanks
Old Dec 7, 2011 | 10:18 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Either of these problems should be addressed because left alone, things only get worse.
The freeze plugs are located on the sides of the block. That's why they are difficult to change. Access to them is very restricted. If the engine is out changing them is a snap.
Also, if you do change the freeze plugs, replace them with BRASS plugs.
The picture is a 360 but a 351 is similar. This engine has the brass plugs in it.
Old Dec 7, 2011 | 10:23 PM
Roelito78's Avatar
Roelito78
Thanks for the info mike! I figure if its the manifold it would be much easier than the plugs. I dont want to pull my engine out. I may take it to a mechanic if its the freeze plugs. The weird thing is that it appeared to have leaked when the outside temps dropped. I will check it out tomorrow morning. Could it be anything else?
Old Dec 7, 2011 | 10:29 PM
plumber01's Avatar
plumber01
Cold weather makes metals shrink some (especially thin metal), it has the opposite effect of heat, which can make metals expand. it sounds like a good bet it's the freeze plugs, but could very well be manifold also. (do you have a reservoir tank? could have gotten such a hairline crack in it too)
Old Dec 7, 2011 | 10:30 PM
plumber01's Avatar
plumber01
i know a great mechanic in Dickinson, he's the only one I take my antique truck to also.
Old Dec 7, 2011 | 10:34 PM
Roelito78's Avatar
Roelito78
Plumber, it does have a resevoir tank but it on the opposite side of the leak. The leak is on the passenger side. Also, if its freeze plugs could it stop leaking when it warms back up? (outside) I would hate to mess with those plugs.
Old Dec 7, 2011 | 10:35 PM
Roelito78's Avatar
Roelito78
Who is the mechanic Robert? Were is his shop? Thanks
Old Dec 7, 2011 | 10:36 PM
plumber01's Avatar
plumber01
I think it would be sheer luck if it did.
Old Dec 7, 2011 | 10:38 PM
Roelito78's Avatar
Roelito78
Is your mechanic reasonable Robert?
Old Dec 7, 2011 | 10:39 PM
plumber01's Avatar
plumber01
jesse automotive on HWY 3 in Dickinson, If you're going down 3 from league city, when you get to Dickinson it's on the left in a little business park just before Deats (theres a stop light @ Deats)
Old Dec 7, 2011 | 10:41 PM
plumber01's Avatar
plumber01
he's extremely reasonable, the first time I met him he did a job that took 30-40 minuets to do and told me not to worry about paying him, just come back if I ever need anything, that was 6 years ago.
Old Dec 8, 2011 | 12:14 PM
Roelito78's Avatar
Roelito78
Well guys it appears that the leak was coming from a heater core hose. I traced the leak and I could see antifreeze running down the side of the heater core case under the hood. I am crossing my fingers. I hope my heater core is not leaking. I will keep you guys posted. Thanks
Old Dec 8, 2011 | 03:37 PM
mark a.'s Avatar
mark a.
Lucky you, freeze plugs are a pia.
