snow wather meth
Old Dec 7, 2011 | 06:41 PM
dmanshane's Avatar
dmanshane
snow wather meth
i have a 2000 7.3 350srw 6spd it has cold air 4inch twurbo back and ts 6 pos chip and ats ported twurbo housing thinking about the towmax water meth from snow any thoughts does it work and does it lower exhaust temp any mine can skyrocket easy pullin
Old Dec 7, 2011 | 06:47 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
I bought one from Snow and I haven't been able to get it to work. Snow is hard to get a hold of n doesn't answer their emails. I've heard good things about them,but I have also heard the meth is hard on the engine. Was told to just run water,if it ever works I will.
Old Dec 7, 2011 | 06:56 PM
dmanshane's Avatar
dmanshane
what about cheep ole wiper fluid
Old Dec 7, 2011 | 07:10 PM
diesel-fitter-bum01
That's basically what boost juice is. It has more meth in it though. Running just water you won't have to waste a tune on it. Water/meth needs special tuning.
Old Dec 7, 2011 | 07:15 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Did you buy it new? Which one did you get?
Old Dec 7, 2011 | 07:29 PM
diesel-fitter-bum01
I bought the stage II from ya Clay. I had a thread going on here trying to get it going because Snow wasn't helping at all. I found a guy here in Nebraska that has experience with them and hes going to look into it this spring. Hopefully before RRE. I think its the computer box that is bad. I tested the pump n it worked fine. I may have had my pump too high. Who knows.
Old Dec 8, 2011 | 12:38 AM
Riffraff Diesel
PREMIUM SPONSOR
If your having issues you need to let me know on that kind of stuff. That's why I am here, to help you more quickly and accurately than you going direct. If it isn't working we need to get your swapped out.
Old Dec 8, 2011 | 03:16 AM
diesel-fitter-bum01
You did give me some suggestions. Then I think I got busy or something,just haven't messed with it forever. I'm sure its out of warranty by now. This guy I talked to said he could look at it n see if he could figure it out. He runs water/meth and turbos on his quads n snowmobiles.
Old Dec 8, 2011 | 07:51 PM
CSIPSD's Avatar
CSIPSD
Check out Cooling Mist for your water injection needs...
Better pumps, controlers, nozzles and people.
I have run Snows, and Cooling Mist. Tested for Cooling Mist as well, just a far better system.
Old Dec 9, 2011 | 09:05 AM
kirkharrod's Avatar
kirkharrod
Save a bunch of money and DIY, rather than buy a kit. My DIY water injection system write up is in this thread.
https://www.ford-trucks.com/forums/9...ml#post9261945
Also, here is where I put my first WI system:
https://www.ford-trucks.com/forums/9...ml#post8686846
Old Dec 9, 2011 | 11:41 AM
timmyboy76's Avatar
timmyboy76
you ever considered having a boost leak?
Old Dec 9, 2011 | 11:42 AM
timmyboy76's Avatar
timmyboy76
meant to highlight this....
eman92082
Dec 16, 2008 07:03 PM
mercman65
17
Apr 25, 2008 08:48 PM
Ian F
Garage & Workshop
25
Jan 31, 2005 05:45 PM
88B_RONC
Texas Chapter
16
Nov 6, 2002 09:06 PM
