DASH BUZZING
Old Dec 7, 2011 | 07:39 AM
01EX's Avatar
01EX
DASH BUZZING
I disconneted my batteries for heater control relay replace.
I reconnected the batteries and turned ignition on waiting for glow plug light to go off, I heard a buzzing noise around he radio.
Shortly after the glow plug light went off the buzzing stopped.
I don't think it's related to glow plug, just trying to give an idea when buzzing stops.
This has happened before when I disconnect batteries but has gone way after a few cycles of the key.
I did a search and tried flashere lights, turn signals to see if it made a difference. No difference.
ANY IDEA'S.
Thanks
Old Dec 7, 2011 | 07:59 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
When the batteries are week, you will hear lots of noise from the dash. Could be the glow plugs were pilling the battery down. Put a meter on the bats while the glow plugs are on and while starting.
I take it the truck started after the buzzing stooped?
Old Dec 7, 2011 | 11:48 AM
wolfman08's Avatar
wolfman08
Quite often, buzzing behind the dash is the result of a failing multifunction switch (turn signal). You can unplug the the connector from the multifunction switch and see if your buzzing stops to confirm. Good luck.
Old Dec 7, 2011 | 12:41 PM
SpringerPop's Avatar
SpringerPop
When you replaced the battery cables on the terminals, did you clean them REEEEEEEL GOOD?
Think "Battery Brush".
Pop
Old Dec 7, 2011 | 06:26 PM
01EX's Avatar
01EX
Thanks for the replys.
1 yr old batteries,clean terminals.
Starts fine.
I will look into the multifunction switch.
Old Dec 13, 2011 | 06:44 AM
01EX's Avatar
01EX
It was the radio/Cd player.
I disconnected radio and it went away.
Handdsaw
Feb 26, 2017 01:45 PM
ZombiePopper
Sep 24, 2014 05:37 PM
mmenzies
Apr 30, 2012 01:45 PM
jiggiwdit
Jan 22, 2008 09:44 AM
FORDSFOREVER164
Dec 3, 2005 06:15 PM
