Dizzy swap DS2 conversion
Old Dec 17, 2011 | 08:46 PM
Wyowanderer's Avatar
Wyowanderer
Originally Posted by BaronVonAutomatc
Indeed, the one with just a single vacuum line.
Forget the HEI, a DSII module is literally plug and play. Unplug two connectors, plug the DSII module and dizzy in, and go. It's just too easy to bother dicking with anything else. You can probably find the whole kit and kaboodle at a yard for less than 50 bucks.
Ditto. The gofastforless swap is a fix for a problem that doesn't exist, unless you want to cobble up your wiring. It's way better and easier to swap in the DSII parts from the start.
Old Dec 17, 2011 | 08:49 PM
Wyowanderer
Originally Posted by CamaroAdam73
I really appreciate the help guys.
I've got the dizzy i need, bought one "new" for 40$ through autozone. Now i just need to find the wiring harness, any advice? If there's a diagram anywhere on how to wire this up myself that would work too.
As for the carb, I'm going to do what i can to run this feedback carb until I'm ready to swap it. It's been rebuilt so it's at least got that going for it. The reason i want to wait is because i plan on finding the right size holley 2/ 4 barrel and buying an offy DP intake.
After that the next and final (hopefully) engine mod will be a header and new exhaust the whole way back.
I plan on keeping this truck for a long time.
I can fix you up with the wiring harness for the price of shipping. Send me a pm if you're interested.
Old Dec 18, 2011 | 07:34 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
This may help you.
Old Dec 19, 2011 | 08:14 PM
CamaroAdam73's Avatar
CamaroAdam73
Alright today i picked up a DS2 module from an auto parts store, 25$ and it came with a lifetime warranty. Also got a coil + wiring harness (+ and - wires), i sourced all of thees parts for a 79' F150 with a 4.9L.
The only things i need are the DS2 harness, and a new dizzy cap/rotor.
Any advice on where i should mount the ignition control module?
Old Dec 20, 2011 | 12:24 PM
Wyowanderer
The module bolts to the left inner fender-there are three holes in the spot where it attaches.
Old Dec 20, 2011 | 03:30 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Put some spacers underneath it to help with air flow. They don't like heat.
Old Dec 26, 2011 | 04:24 PM
CamaroAdam73
Alright i ran into a snag. I've got everything mounted up and my wiring harness made/mounted the duraspark module. Went to fire it up and nothing, it just cranks over.
I'm following the wiring diagram that gfw1985 posted. When i turn the key to the on position i get full 12v at the coil, and 12V at the RED and WHITE wires leading to the 2 prong wiring harness on the ignition module.
I know the dizzy is wired correctly to the module, and so is the coils ground ( - wire). What I'm unsure of is the coils power(+) wire, as well as the wiring from the ignition switch to the ignition control module.
I used the original coils power wire (which is brown) to supply power to the coil. For the ignition control module i used two wires from the 6 prong connector that original connected to the dizzy mounted control module. I used the red 14gauge wire for power, and the black for what i assumed was ground (white wire leading to control module)
What did i do wrong here?
Old Dec 27, 2011 | 09:07 AM
CamaroAdam73
Alright heres an update. still no progress. The weather is ****ing ****ty outside and I'm still walking to work because of this, blah.
The truck just turns over, doesn't start. The battery died so i won't be able to try again untill tomorrow/ tonight. It didn't seem like it was getting spark, i blasted it with starting fluid and choked the engine because it's cold, got nothing out of her, not even a spudder.
Here are some pictures of what I've got going on.
What i did here is temporary for testing only, i didn't want to hack up the original harness yet.
I've got the power (red wire) to the control module wired off of the 3rd wire in on that harness, which is red and a larger gauge than the other. Which also supplied 12V when key is on/ start (assuming running as well)
And the white wire (which retards timing in cold weather to help start?) to the black wire, at the end of that connector, at first. But then switched it to the BLUE wire at the opposite end of that connector.
Here is how i temporary wired the coil, i used the original coils wiring harness. the BROWN wire is what i assumed was the POWER wire, and it supplied 12v to the coil when the key is on. I did not reuse the original harness green wire because the coil gets the - side wired too the duraspark module.
If anybody can help me with this i would really appreciate it! The weather is getting bad up here and if i don't fix this truck soon i'm done with it.
As soon as i can afford it, i'll either buy a factory wiring harness or buy the end connectors (you can get them from autozone believe it or not).
Forgot to mention, i'm not using the original coil, i bought a round older style coil that will work with the new dizzy/ module. I also have the dizzys vacc advance hooked up to what i believe is a ported vac source (doesn't supply vacc at idle). But I'm not 100% on this yet.
Old Dec 27, 2011 | 09:48 AM
JimsRebel's Avatar
JimsRebel
Here is a good read, kind of long, most of the info you need is toward the end.
https://www.ford-trucks.com/forums/1...on-module.html
This is the make your own harness approach.
Dont worry about the white wire (start retard) for now, it will run with out it.
How is the Coil Negitive wire getting to the new DS2 module?
Jim
Old Dec 27, 2011 | 12:54 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Can't check your wiring as I don't have a diagram for your truck. Power to module is red in run, white in start. Make sure you have batt voltage to + side of coil in "start" position. Coil neg should be green from ign module. With everything wired correctly, it should fire, if you dropped distributor in correctly. Good luck.
Old Dec 27, 2011 | 02:53 PM
CamaroAdam73
Jim, the coils negative wire is wired to the green wire from the ignition module, i wired it the same way i did everything else 14/16g wite and crimped female ends. I'm reading that write up now about making your own.
I'm pretty sure i dropped the dizzy in right, but i didn't bring her to TDC like i should have/ I took the "lazy" approach and brang the rotor cap around to where the old number 1 wire sat, then used two rulers and marked on the block exactly where the rotor would have pointed too, then dropped the new dizzy and lined it up. Normally when you drop a dizzy a tooth off it will at least still do something.
Old Dec 27, 2011 | 03:01 PM
JimsRebel's Avatar
JimsRebel
Try the "flashing test light" check.
This test will see if it is all hooked up correct
Jim
Old Dec 27, 2011 | 03:06 PM
  #28
gfw1985's Avatar
gfw1985
Cranky Old Guy
Check to see if you are actually getting fire to spark plugs. If they are getting a good spark, then timing has to be off. Hate to mention this, but you do know the six counts clockwise for firing order instead of counter clockwise, right? I'd rather mention it and take the chance of offending you. At least on the 200/250, I don't have a 300.
Old Dec 27, 2011 | 03:12 PM
  #29
CamaroAdam73
Nope didn't know that, you won't offend me so don't worry. at the very least i appreciate you telling me, all the information i have the better off i am. I did the firing order based off of what it was on the old dizzys cap. 1-5-3-6-2-4
If this helps any, the volt at coil/ module are both 12V with key in ON position, when i turn the key and crank the engine they both drop to 9V.
Right now i can't tell if im getting spark at the plugs or not, i have nobody to help me and its pooring down freezing rain. I'm so close to the end of my rope i could hang myself.
Jim, I don't mean to sound like an idiot, but what page would that test be described on in that thread? there's allot of pages hah.
Old Dec 27, 2011 | 03:25 PM
  #30
JimsRebel's Avatar
JimsRebel
I have a feeling i dropped the dizzy wrong, and the timing is just so out of whack that it won't do anything.
Does the battery drop to 9 volts also?
If the test light flashes the the timing is off.
You can also just hold the coil wire close to a ground and test for spark.
Jim
