This is a little new for me...mechanically, but it could be the DuraSpark ignition module, especially if it's the TFI module mounted on the dizzy...was a POS from day one!
The terd burns out, so...you can crank the engine till he!! freezes over...and beyond, it won't start.
It has electric carb both rotor and cap look ok, tried start spray but no start. Can't hear fuel pumps make noise when key is on position.
That vwhen I started to look for related relays and fuse...could not find.
called local Ford Dealer no help.
