Pulled 2 codes...Help
Old Apr 4, 2009 | 08:18 PM
High Intentions's Avatar
High Intentions
Mod Specialist ;)
The service engine soon light came on and when I got home I pulled 2 codes. 1 was p1247 Turbo boost pressure low. 2 p1107 Dual generator lower circurt.
I been running my dp tuner on 80 econo for about a year. What would cause these codes to pop up???
Eric
Old Apr 4, 2009 | 10:03 PM
DieselCamper01's Avatar
DieselCamper01
Sorry no answer. Here is a bump
F350-6's Avatar
F350-6
Do you have dual alternators? The one that probably set the light is the Turbo code. Do you have any kind of boost fooler? I'd start by checking the hose to the MAP sensor, then the MAP sensor itself.
Old Apr 5, 2009 | 05:06 AM
High Intentions
Mod Specialist ;)
Thats the thing..I do not have dual alternators..The map sensor is on the pass. side right??
Old Apr 5, 2009 | 07:41 AM
F350-6's Avatar
F350-6
What are you using to pull the codes, and what were you doing when you tripped the light? There's a chance those are both false codes and you just tripped an ICP code getting on it.
Yes the MAP is on the passenger side.
Old Apr 6, 2009 | 05:10 AM
High Intentions
Mod Specialist ;)
I have a dtc reader form sears..Can't think of the brand of it right now. I was drive normal...The map sensor hose looks ok.
Thanks for your help and info....
Old Apr 6, 2009 | 08:01 AM
Pocket's Avatar
Pocket
Clear the codes and run the truck again. Then rescan and see what pops up the second time.
