need help with codes
Old Jun 22, 2004 | 08:32 PM
krzyk26's Avatar
krzyk26
My 97 f350 psd has lost most of its power. While in the transmission shop they pulled tree codes. Po113,P0344,P0236. I have a brief explanation for the codes but do not know what route to go. I replaced the cam sensor and could not tell it did any good. That was a costly replacement so before I give up and take it to someone I wanted to see if anybody has had similar problems. any info appreciated, Thanks
Old Jul 1, 2004 | 11:45 AM
91f2504x4's Avatar
91f2504x4
I was wondering do you know what the p0236 code is and what it represents I looked in my code guide and it states that something concerning the Turbo Boost
Old Jul 1, 2004 | 04:41 PM
jeff Heidel's Avatar
jeff Heidel
AT least in the code info for my 2002 the P0113 is "IAT sensor circuit high input" the AIT is the intake air temp sensor. P0344 is CMP sensor circuit intermittent. P0236 is turbo boost A circuit performance. This referes to the manifold absolute pressure sensor (MAP)
Jeff
