starting problems 7.3 help
Old Dec 6, 2011 | 01:33 PM
vetklr's Avatar
vetklr
I have a 2000 f-250 when cold you turn the key on to cycle the glow plugs it only stays on for about 3 seconds then shuts off after you cycle 3 or 4 times you can finaly get it to start runs fine until you shut it off and go back to start it and the glow plug light comes on for 2 to 3 seconds and it shuts off but this time it will not start at all unless you put some gas on a rag and put it in front of the intake runs great when it is running any info would be great thanks
Old Dec 6, 2011 | 01:40 PM
snakedoc's Avatar
snakedoc
check the GPR if it is dead the GP will not work.
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Old Dec 6, 2011 | 02:15 PM
vetklr's Avatar
vetklr
Also the glow plugs and relay ate new
Old Dec 6, 2011 | 02:28 PM
PaysonPSD's Avatar
PaysonPSD
If by "glow plug light" you mean the Wait To Start light it does not indicate that the GPR is operated. It is just a timer. You need to use a VOM or test light to be sure voltage is passing through the GPR to the GPs.
See this THREAD and The Winter Cold Start Sticky Thread (that can also be found at the top of this forum thread index list).
Old Dec 6, 2011 | 02:46 PM
vetklr's Avatar
vetklr
Yes I mean the wait to start light sorry what controls the gpr
Old Dec 6, 2011 | 03:06 PM
PaysonPSD's Avatar
PaysonPSD
The PCM
I posted this in the other thread I linked to but I guess you didn't go to that other thread.
From the Ford Service Manual:
Read The Winter Cold Start Sticky Thread I linked to in post #4. It has great info.
Old Dec 6, 2011 | 03:23 PM
vetklr's Avatar
vetklr
Thanks for the info.
tullie
Oct 21, 2009 07:24 PM
why165
Nov 5, 2006 12:18 PM
chris lacosse
Oct 31, 2006 06:49 AM
1978fordf250
May 2, 2006 11:14 AM
Bflodiesel
Apr 22, 2004 11:44 AM
