Sponsored by: Real Truck
front end noise
Old Dec 19, 2011 | 06:54 PM
  #31
Sickler1's Avatar
Sickler1
Originally Posted by PA-Mark
Not to be smart, but just to be sure, you did jack from the frame. If you jack the axle you will just be checking the wheel ends. Also the size of the prybar must be enough to overcome the weight of the axle wheels tires and suspention componants.
Again just trying to help, Mark
Wish you lived close I would help, instead of just armchair quarterback...
no its all good...ill take any input i can...I call my prybar "tiny" its about 4ft long and 1" round works well!!...i jacked it up from the frame and axle since i had to check the ball joints and tie rod ends...
Old Dec 26, 2011 | 09:36 AM
  #32
08_F350's Avatar
08_F350
I had the same issue and I tested the balljoints as well without any movement. It wasn't until I replaced the balljoints did the clunk go away. I'm thinking that there was just enough play in them to cause the clunk but not enough for me to see it four feet away when using the pry-bar to test them.
jstihl
Dec 28, 2017 08:32 PM
tennesseecoalroller0
Mar 20, 2013 06:35 PM
davew250
Mar 26, 2008 06:54 AM
SKYDAN
Nov 6, 2007 09:31 PM
dempsey64
2004 - 2008 F150
May 4, 2007 06:00 PM
