Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
powertrain id.
Old Dec 3, 2011 | 08:20 PM
luddite's Avatar
luddite
powertrain id.
Am looking at a 1973 truck and would appreciate if someone could help me with the particulars on the drivetrain.
model f81
body 118
trans m
axle e23
vin f81fvr55141
Thanks
Old Dec 4, 2011 | 06:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F81FVR55141 / model F81? / body 118 / trans M / axle E23.
Welcome to FTE
VIN and codes in sequence as stamped on the Warranty Plate:
F81 = L800 (gas).
F = 391 4V FT engine.
V = Kentucky Truck Assembly Plant.
R55141 = 1973.
W.B. (Wheelbase) omitted.
COLOR code omitted.
F81 = L800, but the MODEL code is 4 digits, you omitted the last digit. Without the 4th digit, cannot list the specific GVW
118 = No such BODY code. All this relates to is the seat upholstery, type of cab.
M = Clark model 285V 5 Speed Direct.
E23: E2 = Eaton model 16244 2 Speed Rear Axle / 6.17/8.58-1 / 17,500 lbs. Rear Axle Capacity // 3 = Ford 6,000 lb. Capacity Front Axle without P/S.
GVW (Gross Vehicle Weight Rating range) omitted.
DSO code omitted. 2 digit DSO: City/State Ford District Sales Office the truck was ordered from. 6 digit DSO (if present): Last 4 digits = Domestic Special Order number. Truck was ordered special, not "bought off the lot."
Old Dec 5, 2011 | 04:56 AM
luddite's Avatar
luddite
Thank you! I appreciate it. Model=f310 I omitted the 0. I believe the body=118 but I am reading it off a photograph and may be mistaken. DSO=522641 the GVW=22100.
Your transmission and axle info is great and will allow me to calculate some road speeds and make some semi-intelligent guess's on gradeability. The rig has air brakes which is rare in my part of the country in a vehicle in this GVW range and a huge plus for my intended use. Tilt front end =great access. Only negatives are the lack of power steering and dayton wheels.
Thanks again
Bob
Old Dec 5, 2011 | 05:22 AM
NumberDummy
Model = F810 I omitted the 0.
Your error, you typed F310.
I believe the body = 118
My error, I looked under the wrong truck series.
DSO = 522641 the GVW = 22100.
F810 = L800 (gas), 22,100 lbs. Gross Vehicle Weight Rating.
118: 11 = Meduim Gray Vinyl / 8 = Custom Cab without Butterfly Hood.
522641:
52 = Dallas TX Ford District Sales Office, where the original selling dealer ordered the truck from.
2641 = Domestic Special Order number. Your truck was special ordered by the original purchaser, not "bought off the lot."
Dave Squires
May 9, 2019 08:00 AM
shillinghillf600
Large Truck
Mar 30, 2019 12:16 AM
Elijah Ford
Large Truck
Apr 7, 2018 08:36 PM
mpokoney
Large Truck
Aug 3, 2015 12:08 PM
bleedin'blue
Large Truck
Apr 8, 2012 01:22 AM
