Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Decode Please
Old Mar 29, 2019 | 08:48 PM
shillinghillf600's Avatar
shillinghillf600
Decode Please
Hello all, could someone decode my warranty plate?
Thanks
vin - A80CUF50145
wb - 158
color- blank
model - A802
body - 4N81
trans - C
axle - H7D
gvw - 25500
hp - 208
rpm - 2800
dso - 740593
Old Mar 30, 2019 | 12:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by shillinghillf600
VIN: A80CUF50145 / WB: 158 / COLOR: Blank* / MODEL: A802 / BODY: 4N81 / TRANS: C / AXLE: H7D / MAX GVW LBS: 25500 / CERT NET HP: 208 / RPM: 2800 / DSO: 740593
A80 = F800 (Diesel).
C = Caterpillar model 225 636 cid 8 Cylinder Diesel.
U = Louisville KY Assembly Plant.
F50145 = 1969.
158" Wheelbase.
COLOR: Blank.*
A802 = F800 (Diesel), 25,500 lbs. GVWR
4N81: 4N = Black all Vinyl / 81 = 81A Standard Cab.
C = Fuller model RT-510 10 Speed Direct.
H7D:
H7 = Timken model R171B Single Speed Rear Axle / 6.14-1 / 23,000 lbs. Rear Axle Capacity.
D = Ford Rockwell/Timken 7,000 lbs. Capacity Front Axle.
25,500 lbs. Gross Vehicle Weight Rating.
208 net HP @ 2,800 RPM
740593:
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
0593 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchasers order, making it a Domestic Special Order.
mpokoney
Large Truck
Aug 3, 2015 12:08 PM
stillwater ford
Large Truck
Jul 24, 2015 04:01 PM
Nose is
Jun 5, 2015 03:56 PM
coyote1442
Large Truck
May 20, 2015 05:24 AM
shillinghillf600
Mar 10, 2013 12:19 PM
