Engine Harness
Old Dec 3, 2011 | 07:20 PM
71 Sport Custom's Avatar
71 Sport Custom
Engine Harness
Does anyone carry or reproduce the engine harness' for our trucks? I have a 73 f350 with a 390. Need the harness that plugs in at the firewall and goes to the coil, oil, and water senders.
Old Dec 3, 2011 | 07:34 PM
Edgethis's Avatar
Edgethis
I haven't seen any harnesses specifically for our trucks, or even for the 390. You're prolly just gonna have to make one or fix yours. Are you completely missing it or is it just mangled?
Old Dec 3, 2011 | 07:51 PM
71 Sport Custom
The harness in there now is very brittle from heat or worse. A, most, or all previous owners decided to monkey with the wires and ends. This is the best of many I had at the shop. Any ideas on where to get the correct ends for coil and sensors? I have 12 volts at my coil and not sure if thats legal?
Old Dec 3, 2011 | 08:06 PM
MAULMAUL's Avatar
MAULMAUL
I just got the complete rewiring kit from Painless Wiring. It has everything that you would pretty much need in it. I am sure that you could purchase just the fuse block and engine compartment wiring since the kit is comprised of sections anyway. They aren't cheap, and I mean "really" not cheap. All the wires are color coded and numbered so the install should be pretty easy. Good luck with whatever you decide to do.
Old Dec 3, 2011 | 08:23 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Wire assy, dash panel to engine gauge feed
Fits '73 F100-350 w/360-390 w/o engine diagnostics
D4AZ-14289-R
NOS Parts Source, Olathe, KS has 1 (913) 220-5746
Giesel Motors, Inc. Okarche, OK has 1 (405)263-7242
There is also another dealer that has 2, but I usually don't list him because he has a track record of sc***ng the customer pricewise on obsolete parts.
If you want his name let me know.
Keith Wells
Sep 4, 2017 09:43 PM
brian1080
May 22, 2013 10:09 PM
supercabfreak
Nov 22, 2010 08:56 PM
SuperBeaner
Jun 7, 2010 11:04 PM
Paddy1998
16
May 16, 2008 01:19 PM
