Does anyone carry or reproduce the engine harness' for our trucks? I have a 73 f350 with a 390. Need the harness that plugs in at the firewall and goes to the coil, oil, and water senders.
I haven't seen any harnesses specifically for our trucks, or even for the 390. You're prolly just gonna have to make one or fix yours. Are you completely missing it or is it just mangled?
The harness in there now is very brittle from heat or worse. A, most, or all previous owners decided to monkey with the wires and ends. This is the best of many I had at the shop. Any ideas on where to get the correct ends for coil and sensors? I have 12 volts at my coil and not sure if thats legal?
I just got the complete rewiring kit from Painless Wiring. It has everything that you would pretty much need in it. I am sure that you could purchase just the fuse block and engine compartment wiring since the kit is comprised of sections anyway. They aren't cheap, and I mean "really" not cheap. All the wires are color coded and numbered so the install should be pretty easy. Good luck with whatever you decide to do.
Wire assy, dash panel to engine gauge feed
Fits '73 F100-350 w/360-390 w/o engine diagnostics
D4AZ-14289-R
NOS Parts Source, Olathe, KS has 1 (913) 220-5746
Giesel Motors, Inc. Okarche, OK has 1 (405)263-7242
There is also another dealer that has 2, but I usually don't list him because he has a track record of sc***ng the customer pricewise on obsolete parts.
If you want his name let me know.
