Random Coolant leak...
Old Dec 3, 2011 | 01:44 PM
bjvagts's Avatar
bjvagts
This moring when letting the truck warm up before leaving work(temp about 25 degrees) small leak developed on the back side of engine dripping off the bell housing. 1st thought it was fuel(drain valve o rings again) but after getting home to investigate determind it was coolant. heres the kicker, no leak. Let it run a bit no leak. let it sit and cool off(temp in the low 50's now) the started but still no leak. The radom leak came somewhere from the driver side rear towards the top. I can see where it has dripped on driver side exhaust up pipe. Things i've checked.
Water pump good
engine valley dry
oil good
antifreeze good
when engine runs no smoke.
oil cooler tube clean.
radiator hoses all good
thermastat housing good.
Not sure where else to check or where to look. Any help would be great.
2000 F-250 manual transmision.
Old Dec 3, 2011 | 01:54 PM
Robert6401's Avatar
Robert6401
I had a pinhole leak in my radiator that I could only find by pressurizing the entire system with the truck off. Don't know if you have a kit, but a general mechanic would.
Old Dec 3, 2011 | 02:04 PM
Bonanza35's Avatar
Bonanza35
Is there a coolant drain plug back there. maybe one of them are leaking and just needs to be tighten up.
Old Dec 3, 2011 | 02:09 PM
bjvagts's Avatar
bjvagts
There is 3 plugs and the back side of the head. One being a freeze plug and 2 others not sure what they are. Think one is for the fuel rail but thats just a guess.
Old Dec 3, 2011 | 02:13 PM
Tailgate77478's Avatar
Tailgate77478
Sometimes the symptoms you describe occur when the water pump seal starts to go bad. That is, it will leak overnight when the engine is cool and sitting...but won't leak when the engine is hot. I guess it has to do with the metal around the seal swelling a bit, not sure. Something to think about though.
Old Dec 3, 2011 | 02:21 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
I was thinking oil cooler.
Old Dec 3, 2011 | 02:25 PM
bjvagts's Avatar
bjvagts
The leak started while the truck was warming up and coming from the back side of the engine. After a bit leak stopped and haven't been able to get it to leak which is good I guess but would like to know where it came from.
Old Dec 3, 2011 | 02:26 PM
bjvagts's Avatar
bjvagts
The oil cooler looked ok no leak there.
Old Dec 30, 2011 | 05:19 PM
jcrammell's Avatar
jcrammell
Did you ever find that coolant leak? I have just started getting a coolant leak but can't tell where it is coming from.
Old Dec 30, 2011 | 05:49 PM
kawcrasher's Avatar
kawcrasher
On the commercial side they call these "cold leaks" and don't worry about them. My DD Series 60 would lose close to a gallon a weak sitting in the winter. Not a drop any other time.
Colonel11
Nov 22, 2014 08:50 PM
tom_delonge2289
Dec 1, 2007 09:03 AM
Mike Swann
Mar 22, 2007 02:20 PM
wolftan
Mar 2, 2006 02:00 PM
TexasGuy001
Feb 25, 2004 09:14 AM
