FICM
Old Dec 2, 2011 | 02:29 PM
firedaniel's Avatar
firedaniel
FICM
Quick question the truck is starting fine... I have a scanguage that is hooked up reading the voltage on the FICM. When I start the truck the voltage runs about 42 volts until the glowplugs turn off and the alternator kicks in. It then runs on up to 48v and stays pretty consistent. Does this sound right or does the FICM need to be worked on... Just curious your thoughts as I try to make this truck as reliable as possible...,
Thanks
Daniel
Old Dec 2, 2011 | 02:40 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Rule of thumb is "under 45v, time to fix"
Old Dec 2, 2011 | 02:45 PM
Ricson's Avatar
Ricson
Your voltage is getting low. Talk to Ed at FICM Repair.com - Your Source for FICM Repair he has excellent customer service.
Old Dec 2, 2011 | 02:56 PM
firedaniel's Avatar
firedaniel
Thats what I was wondering.... I guess Ill get it sent in here soon.
Thanks
Old Dec 2, 2011 | 03:27 PM
Kert0307's Avatar
Kert0307
I would look at the condition of the batteries first.
Old Dec 2, 2011 | 03:37 PM
dchamberlain's Avatar
dchamberlain
Check the battery voltage at startup until the glow plugs turn off and the alternator turns on. If it is low enough it might be bringing down the FICM. Also check the battery and ground connections.
It is most likely the FICM, though.
Old Dec 2, 2011 | 03:38 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
+1 on the batteries/alternator (s)
Old Dec 2, 2011 | 05:51 PM
Nice Work Truck's Avatar
Nice Work Truck
Thanks
Daniel
Mine just started doing this also, 42-43v after a long park overnight.
In is fine once it is warmed up and I start her up.
Maybe I need to start saving for a Swamps 58v unit.
Old Dec 2, 2011 | 06:06 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I've read some posts where the 58v FICM mod isn't particularly helpful or reliable.
Old Dec 2, 2011 | 06:22 PM
Nice Work Truck
Really, I have not seen that.
Maybe I should just do the 48v unit.
Old Dec 3, 2011 | 01:59 PM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
Ricson, I did some research regarding Ed @ FICM Repair. He genuinely cares about customer service, and his prices are fair, especially considering what he does to each unit. I am going to use him moving forward. Thanks for the tip, reps given.
Old Dec 3, 2011 | 02:02 PM
SoCalSuperDuty03
Andy, I had a couple friends do the 58V units, neither lasted long. The heat built by those 'upgraded' units was crazy! Not sure if the heat was the mitigating factor in the failure, but I am sure it didn't help.
Old Dec 3, 2011 | 07:14 PM
Nice Work Truck
Thanks for the input Socal.
I need to rethink the 58v.
Old Dec 3, 2011 | 09:36 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
We don't suggest the higher voltage modifications for precisely the reasons stated here.
The easiest and certainly most reliable path to better cold starting is migrating to 5W40 synthetic oil. The difference is night and day, especially in those cases where stiction has already begun to set in.
Thanks for all the positive comments about our service, guys. It is much appreciated.
Ed
Ed@ficmrepair.com
Old Dec 3, 2011 | 11:26 PM
SoCalSuperDuty03
Ed
Ed@ficmrepair.com
Ed I don't know you personally.... yet. I tend to thoroughly research businesses prior to becoming a customer, and once I do, and they pass the test, I keep those business relationships forever. You will hear from me in the future. Take care.
