Springs
Old Dec 2, 2011 | 07:47 AM
Hellonwheels's Avatar
Hellonwheels
Springs
Thinking about putting some stiffer springs on my f350 and i found some on a 97 fsuperduty that was an ambulance, it has an impressive set of springs and helper springs too! Im pretty sure they are too long tho, can anyone up here confirm whether they will or wont work without me going way out my way to the junk yard to measure them again?
Old Dec 2, 2011 | 10:42 AM
starmilt's Avatar
starmilt
I bought some new take off springs off of an ambulance and installed on my old 79 wrecker.
It lifted the rear quite a but, and I had to drill out my spring hangers, but the length.
The company that built the ambulances where I got them changed out the springs for softer springs for the ride, so you may not be getting what you think you are.
Old Dec 2, 2011 | 11:49 AM
AirLiftCompany's Avatar
AirLiftCompany
SPONSOR
If you are just looking to stiffen your suspension you may want to consider using air rather than possibly stiffening it too much with the springs you mentioned.
Our kit for your truck is 57215.
This will probably be more expensive than a set of springs from a junk yard, but I think long term you would be far happier with ride quality.
Old Dec 2, 2011 | 07:27 PM
Marianna2003's Avatar
Marianna2003
I'd use use the main leaf and every other leaf with the air bags for ride and capacity. Adjust the air pressure to where you want it to ride and you
are good to go without losing a kidney.
17witha664x4
Feb 3, 2012 03:22 PM
Rick2001
Jun 18, 2010 10:01 PM
balderman
Apr 12, 2009 09:31 PM
s2gots
May 18, 2005 03:14 PM
j gibbs
May 12, 2003 01:40 AM
