Air intrusion
all my glow plugs check out and its getting hard to start.
if there is a leak before the e-pump though,it's not going to help as it will still stuck air of course.
they do have check valves in them though,which means fuel can only go back so far (again if the leak is not pre-pump.)
so in short,even if fuel has left the building lol.an e-pump should prime the system and have her ready to fire once the WTS light is out.
an air intrusion issue is not often a hard start,because the ip still has lots of fuel in it so it's going to run on that.if she stalls out after an easy start,then you know fuel has drained back.
a hard first start,followed by no stalling,indicates generally a starting system,or glow plug system issue.
to have a diesel fire up instantly when its cold,you need (listed in order of importance imho) :
1.good compression.
2.good starting system.
3.good GP system (or other heating device.)
4.good fuel system.
5.power at the FSS.
notice the list of importance doesn't include actually firing up running until she'll made to turn over super strong again,in fact getting fuel (to actually run) is pretty much the last concern if your looking to gain instant cold starts that is.
1.good compression.
4.good fuel system.
5.power at the FSS.
your best explanation is what he has to say here...
