How do I identify what trans?
Old Nov 30, 2011 | 08:13 PM
fordboy300's Avatar
fordboy300
Question How do I identify what trans?
Well i thought i had the Clark 3 speed overdrive (4th gear being overdrive), but today i went on alldata to look a procedure and it asked with Warner or without Warner transmission?
Is it the same transmission? Could someone help me out my truck is a 86 f150 with the 300 six
Thanks
Old Nov 30, 2011 | 08:23 PM
Franklin2's Avatar
Franklin2
Do you have a granny 1st gear?(very slow, little used)
Old Nov 30, 2011 | 09:39 PM
fordboy300's Avatar
fordboy300
if you mean is my 1st gear is short (up to 15 mph) then yes i have a granny 1st gear
Old Dec 1, 2011 | 03:36 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Have a look here; Domestic Truck Tranny Guide
Old Dec 1, 2011 | 08:17 AM
Eightyfive Flareside's Avatar
my granny low was like 1-4 mph, that was t-18
Old Dec 1, 2011 | 08:20 AM
lavatan's Avatar
lavatan
Yeah, I can't get above 10 without serious RPMs. I could pull a house down but nothing else in 1st. I don't even realize it's there anymore except when pulling. IIRC if you can look, there is a model number on the top of the transmission that will say T19, if that is what you have.
Old Dec 1, 2011 | 04:33 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The T-19 has a PTO cover on the drivers side (and a syncro 1st gear)
The T-18 only has a PTO cover on the passenger side, and no syncro 1st.
Old Dec 1, 2011 | 04:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks
The TRANS code is printed on the Certification Label. Three possible 4 speeds were available for 1986 F150's.
A = New Process 435 4 speed / B = RTS SR-OD single rail 4 speed overdrive / F = Warner T-18 4 speed.
P = Warner T-19 4 speed, but was not available in F150's. F250/350's only.
Big John Hance
Oct 5, 2022 09:40 AM
Brandon1986
Jun 2, 2012 05:45 AM
rick4106
May 3, 2010 11:08 PM
Mky67156
Aug 12, 2003 09:41 AM
