HELP !!! J/K...
Old Nov 30, 2011 | 08:05 PM
sand_fiend's Avatar
sand_fiend
HELP !!! J/K...
Hey guys.. I just got my gauge kit today. I have already mounted the gauges in the pillar, Mounted and ran the wires and hose down through the dash.
#1 on the boost fitting, It says to drill and tap then mount it on the intake ? Where did you guys install yours?? Where is the best place ?? Any picture would be great !!!..
#2 On the egt censor, It says to drill and tap also.. where is the best place to mount it ??
thanks, Phil
Old Nov 30, 2011 | 08:35 PM
woodnthings's Avatar
woodnthings
Check out Figure 17 and 18 of Riffraff Diesels Gauge Install Instructions. That will give you one way to do the boost, right off the MAP sensor line.
Or, you can do the IAH Delete and use a tapped plug like I did. I use a QD fitting for air lines.
Old Nov 30, 2011 | 09:44 PM
sand_fiend's Avatar
sand_fiend
I looked around for info and could not find any...
Well, after not looking, I found it... thanks anyway guys..
Guess i should do a deeper search on a subject before asking..
Gear619
23
Feb 14, 2016 12:39 PM
F350mikey
Sep 28, 2007 06:03 PM
just2dune
Jun 23, 2006 06:04 AM
John Kiernan
May 15, 2005 09:20 PM
TEXASBIGRED
Oct 10, 2003 10:42 PM
