Steering Column
Old Nov 30, 2011 | 07:43 PM
Leidy's Avatar
Leidy
Steering Column
I need to put a new steering column in my 1994 F-250 manual trans. I am having problems finding one for my truck. I found one for an F-150 on ebay that is manual, but I'm not sure if there would be any difference in the steering shaft diameter or length. The column I am looking at also has the air bag setup where mine doesn't. But I am also not sure how hard it would be to remove that hardware. If you don't think this column would work could you lead me to a place where there is one for sale on the internet. The truck ran out of inspection so I need to get one asap. Thanks in advance,
Leidy
Old Nov 30, 2011 | 07:52 PM
deljac's Avatar
deljac
the one for an f150 will work. i just put one out of a 95 f150 into a 93 f250 and i just left the airbag in ther its just not hooked up.
Old Nov 30, 2011 | 08:03 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Bingo....Just remove the bolt for the steering shaft U joint, and the 4 nuts that holds the column up.....Other than unhooking/ hooking up the Ignition switch, etc...Plug and play....1 hr job....
Old Nov 30, 2011 | 08:04 PM
Leidy's Avatar
Leidy
Thank you for your response. Did you run into any problems when you did the swap at all?
ragboat
Mar 24, 2018 08:16 PM
crazy4wdracer
Jun 12, 2013 10:49 AM
Jacks 65
Mar 17, 2012 04:30 PM
66f-100
Apr 9, 2011 05:58 PM
