Camshaft ID
Old 11-30-2011, 12:28 AM
watsobs329nl's Avatar
watsobs329nl
watsobs329nl is offline
Camshaft ID
I just tore apart my 460 and I can't find the ID of my Cam. It just has BB at the bottom and 16 stamped a couple lobes up from the bottom. Any ideas?
Old 11-30-2011, 10:53 AM
mark a.'s Avatar
mark a.
mark a. is offline
The 16 is probably a factory marking for the motor it would fit in before grinding. I'd like to say BB means big block but you never know. Are you thinking it might be a aftermarket cam ? The only way to know anything about it now is to put it, degree it in and check it all over.
Old 11-30-2011, 11:19 AM
OverReved's Avatar
OverReved
OverReved is offline
If the cam is stock, here are the specs. Lobe lift, intake=0.2530 in. exhaust=0.2780 in. Hope this helps. The rocker ratio should be 1.73 to 1.
Old 11-30-2011, 05:28 PM
watsobs329nl
I found the Cam ID. Its OEM for the 429 "thunderjet". The BB is the ID except the first B is backward. Thanks for the help guys.
Old 12-01-2011, 07:22 AM
OverReved's Avatar
OverReved
OK, the specs. for the 429 cam are different than the 460. I'm not sure about the "ThunderJet", I could only find one listing for the 429. Anyway, here they are intake=.2526, exhaust=.265
OK, time for more coffee. They are the same. Don't get old.
barnfind 51
05-04-2011 05:36 AM
CA Viking
02-25-2008 06:04 PM
russrobbins
03-03-2007 03:42 PM
fordman428
12-05-2003 03:51 PM
Quick Reply: Camshaft ID
