Cam ID
Old Feb 25, 2008 | 01:41 PM
CA Viking's Avatar
CA Viking
Cam ID
Pulled the cam out of my 78 302 (project motor) and was trying to identify the camsaft. It is stamped "Edel 931451 and 122" Not sure if anyone can help determine if it is stock or if an after market cam and what the specs may be. I took it by the local Ford dealer as well as an engine shop and neither could help... Also, would like to know if a double roller timing set is stock? thanks in advance.
Old Feb 25, 2008 | 01:49 PM
Conanski's Avatar
Conanski
Sorta sounds like it might be an Edelbrock cam....
If you have a dial indicator and a degree wheel you can measure lift and duration yourself.
Old Feb 25, 2008 | 06:04 PM
baddad457's Avatar
baddad457
I think Edelbrock only uses two small block grinds. The Performer cam's part number ends in "122" Basically an "RV" type cam, .448/.472 lift--204*/214* duration @ .050
