I'm in the process of putting a 88 351 windsor and tranny in my 66 and wondering about the egr and smog pump. Would if affect the computer if they were discarded. This is a mass air system engine pulled out of a ford van that was a real good runner.
You are correct, it's the speed density system. I did find some info on fuel injection systems online. It said the O2 sensor is ignored by the computer under hard load or full throttle but output from it is used to make corrections at cruise.
The next question is eliminating the air pump which injects air into the exhaust ports to reduce NO emissions. I guess if the O2 sensor is gone it could be eliminated also.
I left the EGR in place on my EFI. I removed the air pump and all the paraphernalia. I get the egr differential pressure codes thrown but it does not lite the MIL. Runs fine.
It's not a 351, but on my speed density EFI 300 I took off the air pump and catalytic converters (must be removed if you remove the air pump), but I left the O2 sensor and the EGR in place, and it runs great.
I tried it for a while without the EGR, but it didn't seem to run as good and fuel mileage suffered so I put it back.
I have the wiring harness from the 88 econoline and put the computer behind the glovebox. We cut a hole for the harness and it was long enough to reach. The 88 had a C6 so it bolted right up to the frame. I haven't got arround to the throtle linkage yet. I plan on using a aftermarket fuel pump but I do have the 2 tank fuel sistem from the van.
I put a '91 Mustang 5.0 (mass air) engine and T-5 trans in my '64 Falcon. Got rid of both smog pump and EGR. Am running O2 sensors right close to the end of Hooker Super Comp headers. Engine runs great. I'm sure it would trip a "check engine light" if I had one so I elected not to have one. Been running this set-up for more than 10 years with no problems. Good luck with whatever you decide.
