Eec Help
Old Apr 5, 2005 | 09:26 AM
johnnyo888's Avatar
johnnyo888
Eec Help
Can anyone tell me if a speed density computer will operate a Mass Air Flow system?
Old Apr 5, 2005 | 10:02 AM
EPNCSU2006's Avatar
EPNCSU2006
No it will not. It is the computer that determines what type of EFI the vehicle is. The programming is different between the two computers.
Old Apr 5, 2005 | 05:46 PM
88F-150pimp's Avatar
88F-150pimp
No, a speed density computer picks up a frequency signal from the MAP, while a MAF sensor has varying voltage output signal. Also, i belive the trucks with MAF have a couple more O2 sensors and stuff.
Old Apr 5, 2005 | 05:54 PM
andym's Avatar
andym
Can we at least agree that they're different and not interchangeable? I think that was the point....
Old Apr 5, 2005 | 06:02 PM
frederic's Avatar
frederic
They are different and not interchangeable.
Old Apr 5, 2005 | 07:28 PM
EPNCSU2006's Avatar
EPNCSU2006
Yeah, non interchangeable. I shouldn't go on, but the type of input the computer receives is irrelevant. Even it the map sensor was a voltage varying input to the computer, attaching a voltage varying mass flow meter to the same input would not work. You have a speed density computer, and a mass air computer which are not one in the same.
