Thermostat?
Old Nov 29, 2011 | 07:01 PM
FTE Herman's Avatar
FTE Herman
Thermostat?
Question: started in 36 degrees ambient temperature and left *FOR EVER* what is the highest temp you would expect to see on the digital readout for oil temp? I'll give you a hint: I'm disappointed and cold.
Old Nov 29, 2011 | 07:06 PM
Painted Horse's Avatar
Painted Horse
I started my truck and let it idle while I finished breakfast yesterday. When I got in the EGTs were only 198° . So doubt the oil temp could get any higher than that and would be something lower than that. There is not much heat generated at a lean idle. Now if you start to move the truck and get a little richer fuel mix, Then your EGTS jump up and the coolant and oil would warm up.
Old Nov 29, 2011 | 07:21 PM
Glockin' Bob's Avatar
Glockin' Bob
Total WAG - oil temp 120 F. ??? Diesels don't generate much heat idling.
Old Nov 29, 2011 | 07:26 PM
ruschejj's Avatar
ruschejj
Mine idled for almost 15 minutes at 36 or so this morning. Only got up to 89F. But within 5 miles of towing a small trailer it was hitting 200F.
Old Nov 29, 2011 | 07:28 PM
FTE Herman's Avatar
FTE Herman
145 degrees. I kind of figured that diesels (this is my first) would be slow to warm given the lean idle but sheesh - can't they put a cotton-picking thermostat in these things that will get them up to operating temp? I can just see it now: when I finnaly 'ditch' it on the Interstate given one of Indiana's finer weather days I'm going to freeze to death.
That an all of a sudden I seem to have developed a nasty (low amplitude) vibration at idle that seems like the motor is sitting solid against some other part of the truck. I'm starting to get disappointed for $60K.
Old Nov 29, 2011 | 07:42 PM
unstuckables's Avatar
unstuckables
You could do the high idle mod to get hotter temps faster.
Also, I seem to remember an old post about a loose motor mount(or something else loose in the engine compartment) that was causing a weird vibration noise. I memory serves, there were a few members that had that issue.
Old Nov 29, 2011 | 07:44 PM
senix's Avatar
senix
You won't freeze. I started mine in -1F before staying at a hotel in Kansas. Not plugged in either.
within a couple miles It was pushing big heat. got to work it to produce the heat.
Old Nov 29, 2011 | 07:56 PM
vloney's Avatar
vloney
Thermostat........yep, 4 of them.
Old Nov 29, 2011 | 07:59 PM
FTE Herman's Avatar
FTE Herman
Yes guys, driving down the road is just fine. I'm just surprised by how many 'interesting differences' exist between these and gassers.
In all honesty I can't believe it took me so long to come over to the dark side. I wish, I could in a few words share a lifetime's experience with turbocharging/supercharging gas motors and their inherent fragility (even after you put pistons/rods/cranks, the block is still weak) only to finally arrive at a vehicle that has an 'appropriate' amount of torque right from the factory.
Old Nov 29, 2011 | 08:00 PM
FTE Herman's Avatar
FTE Herman
4 thermostats Vince? No kidding?
Old Nov 29, 2011 | 08:15 PM
vloney's Avatar
vloney
Primary and secondary cooling system, 2 each. Because of the radiator issues in the 6.4, the thermostats open at different temperatures to prevent "thermal shock" when a large rush of coolant reaches hot components. Effective for that, but side effect is frozen owners.
Old Nov 29, 2011 | 08:59 PM
kper05's Avatar
kper05
This is where the rapid heat option comes in handy (for frozen owners) because it's an electrical heater coil, correct?
Bigtruc
20
Dec 26, 2013 10:24 AM
Farmboypowerstroke
Apr 2, 2010 08:49 AM
jtharvey
Jan 24, 2007 09:37 AM
TRX250R87
2004 - 2008 F150
Dec 21, 2006 08:57 PM
Petiboy
Oil & Lubrication
Nov 1, 2003 11:30 PM
