05 Alternator help
Old Dec 4, 2011 | 01:41 PM
snorindad's Avatar
snorindad
I have not done it in years but some part stores use to see alt and starter kits. The alt. kits had a new bearing, diodes, brushes and regulator I think for a fraction of the cost and was not hard to do. Does anybody know it they still sell these kits. I know you can still have bad windings but you can test for that before you purchase the kit.
Old Dec 4, 2011 | 04:14 PM
chas111's Avatar
chas111
with a DMM, I am at about 12.5 after truck has been running awhile.
Old Dec 4, 2011 | 08:47 PM
John Irwin's Avatar
John Irwin
When I first got my truck, I was changing alternators regularly. Now I don't any more, and it's because of one or two things, don't know which.
1. I quit using new alternators from an electrical repair shop (probably made by a honest and hard working 9 year old in China) and put a Ford rebuild in.
2. I found bared wires on the alt harness by accident when changing my egr valve, I had a screwdriver or something metal trying to get the valve out and seen sparks when I touched the wires. It was (possibly) shorting on the intake manifold.
Old Dec 4, 2011 | 10:19 PM
BLADE35's Avatar
BLADE35
Originally Posted by chas111
can a person check voltage with a DMM right at the battery?
thats the best spot there canbe some voltage drop if you get the reading eleswhere But should be minimal at that
You would need to unhook the batterys from each other if your load testing them
Old Dec 5, 2011 | 08:21 PM
97TexasAggie's Avatar
97TexasAggie
Well I just got done changing my alternator. Bought a new one from Auto Zone (135 amp). I found a link somewhere in here for "the Power Stroke Tool" and it was by far the best $30 I've spent in a while. It took me 20 minutes with a headlamp and in the cold weather to figure out where to get it hooked in and the rest was as easy as the video on their website. www.powerstoketool.com.
I guess just pulling on the serpentine belt works well if you know what you're up against, but this made the whole thing a piece of cake.
Hunter,DDS
Dec 11, 2010 06:44 PM
JimBrazil
Apr 9, 2010 07:55 PM
DieselFuelOnly
Jan 29, 2006 02:36 AM
z 97ford1
1997 - 2003 F150
Sep 18, 2003 12:34 PM
