how long does an alternator last?
Old Dec 10, 2010 | 09:13 PM
Hunter,DDS's Avatar
Hunter,DDS
Have an 05 psd 6.0. Put new batteries I. Her this summer just because I found a good deal on them. Alternator is original. Edge insight reads good voltage, around 12.5 to 12.7 depending in load. I'd like to replace my alternator before it even thinks of going south. I'm not running any electronics in the truck except the factory stuff. About how long should I have on this alternator? Have 65,000 on the clock. Any suggestions?
Old Dec 10, 2010 | 09:25 PM
hubler13f's Avatar
hubler13f
I have an 05 with 82,000 miles on it and just had the alternator go south. It was reading about 9.5-10.5 and would stick around that so I threw a new one in and it reads around 13.75.
I believe alternators are one of those things that it is hard to put a life expectancy on, some will last the life of the truck and some may crap out in a year and a half.
The saying "If it ain't broke, don't fix it" comes to mind
Old Dec 10, 2010 | 09:30 PM
plomerostroker's Avatar
plomerostroker
I have an 04 with 50,000 miles, mine when out last year. took out ficm. loved that! why didn't I know about this site a year ago. If only, if only!
Old Dec 10, 2010 | 09:31 PM
ljutic ss's Avatar
ljutic ss
My 2003 truck altenator lasted 118,000 before it went out. My 1994 Explorer it lasted until I junked it, 287,000
Old Dec 11, 2010 | 12:56 AM
Gmcbuffalo's Avatar
Gmcbuffalo
Mine has gone south also. I would never know it was going bad if it wasn't for the CTS, it keep giving me a beep alarm for low voltage. I charged the batteries and took it to Les Schwab's and they told me one bad battery. Took then to the dealer because two years ago I replaced both batteries and FICM, so the batteries had a 5 year warrranty on them. The dealer told me the alternator was shot at 62,000 miles.
Old Dec 11, 2010 | 01:32 AM
PowerStrokeHD's Avatar
PowerStrokeHD
Not sure what it is with these alternators, but based on what I have seen if you get 100K out of one you are doing pretty good...
Old Dec 11, 2010 | 04:54 AM
npccpartsman's Avatar
npccpartsman
Talked to an alternator repair shop yesterday about replacing the rectifier in my 2yr old alternator and they told me that if it wasn't for motorcraft alternators they wouldn't be in business. Sad Sad Sad.
Old Dec 11, 2010 | 07:26 AM
Sullid01's Avatar
Sullid01
What voltage would you say indicates a bad alternator? I recently got a CTS so I can check it now. Batteries are both new January 2010. When I first turn it on, voltage reads 11.1-11.3, then after starting and driving for a few minutes (at least 5-10) it slowly climbs to 13.1-13.4. It is the original alternator. It starts fine. The old batteries (advance auto) were bought by the original owner and had stickers indicating they were only 20mo old when they went. Do you think this alternator is going south? Thanks
Mileage 41K
Old Dec 11, 2010 | 09:25 AM
69cj's Avatar
69cj
Mileage 41K
Sounds good to me. That 11.3 is when the glow plugs are on. When they time out then the voltage starts climbing.
Old Dec 11, 2010 | 09:28 AM
npccpartsman
Sounds good to me too. My factory alternator would very rarely hit over 13.5 volts at any time.
Old Dec 11, 2010 | 09:44 AM
John Irwin's Avatar
John Irwin
Is it just me, or does anyone else think the OP's voltage is way too low? Mine runs between 13.8 and 14.2.
Sullid01's Avatar
Sullid01
Thanks guys! Good to know.
Old Dec 11, 2010 | 12:04 PM
davidkstyler's Avatar
davidkstyler
A good battery should read about 12.5v with everything turned off. Use a voltmeter at the battery terminals. There are some good posts on testing batteries.
While the glowplugs are on (can still be on after dash light goes off) the system voltage typically reads about 11.5v.
When the alternator starts charging you should see 13.5-14v.
If you really are running at 12.7v you have a problem.
Old Dec 11, 2010 | 02:56 PM
moebdick's Avatar
moebdick
It's not just you. Mine also runs at least 13.8.
Old Dec 11, 2010 | 03:00 PM
smokersteve's Avatar
smokersteve
mine stays between 13 and 13.8.
