05 Alternator help
Old Nov 28, 2011 | 09:27 PM
97TexasAggie's Avatar
97TexasAggie
05 Alternator help
Looks like my alternator is going out again. Second one and this one only lasted about 30k miles. I have the 110amp single setup. Can I upgrade to the 140amp without changing wiring? Also can anyone address the "build date" differences I'm seeing at the various parts stores? What's the difference between these alternators. I'd like to have the extra power although the only real accessory I have is a transfer flow fuel tank (not sure how many amps that draws). I figure it can't be much except when the fuel pump is on.
130,000 miles and I've loved driving every single one of them.
Thanks.
Old Nov 28, 2011 | 09:35 PM
bismic's Avatar
bismic
No need to upgrade wiring for the 140A unit.
Old Nov 29, 2011 | 10:53 AM
BLADE35's Avatar
BLADE35
My last Motocraft alternator only went 5000 miles and that might be giving it some
I went with DC Power so far so good
make shure all your grounds and stuff are clean dont want the new alternator to work itself to Death
Old Nov 29, 2011 | 11:31 AM
onuredneck707's Avatar
onuredneck707
Along these same lines, I have a Scangauge II and I am wondering if my alternator is working correctly. What voltages should I be seeing? When I first start it up and it is idling, it is around 12.5V. Once I start driving it is 13.7-14.0V. How can you tell if your alternator is dying?
Old Nov 29, 2011 | 11:48 AM
Misky6.0's Avatar
Misky6.0
With the PSD, the glow plugs being "on" disables the alternator
from outputting. I believe this is because the current draw of the
glow plugs exceeds the alternator so this is to save the alternator.
I wait to move my PSD until the alternator kicks in (voltage goes back to 13.6+). I also leave my auto-headlights off, and the same with my
auto-HVAC system. I wait to turn things on until the voltages rises
indicating the alternator is online.
Old Nov 29, 2011 | 11:59 AM
onuredneck707
So the voltages I am seeing are normal?
Old Nov 29, 2011 | 12:10 PM
Misky6.0's Avatar
Misky6.0
It would seem so. The glow plugs can remain on for "up to 2 minutes".
The only indication they are on/off is the voltage.
Old Nov 29, 2011 | 12:20 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Good point! I don't think most guys even consider the accessory load. Seat heaters are another big load if your truck has them.
Old Nov 29, 2011 | 12:22 PM
Rusty Axlerod
Sounds pretty strong. I don't see a problem with those numbers.
Old Nov 29, 2011 | 01:46 PM
97TexasAggie
My alternator light has been coming on and off for a while now. Nothing consistent, but at idle it drops from around 13.5 to 12.0-12.5v. My batteries definitely needed charging this past weekend. The light has come on quicker and stayed longer over the past month.
Does anyone know what's up with the different alternators? Seems to only affect rebuilds. Autozone shows some as "built to11/03/2004" and "built from 09/15/2004". I'm planning on just buying new anyways, but don't want to get the wrong thing.
Old Nov 29, 2011 | 02:39 PM
Misky6.0's Avatar
Misky6.0
Be aware, low voltage will lead to a failed FICM which is $$$$.
Bad batteries can kill the alternator, so when you buy new batteries
(always buy 2 new batteries!) only to find they won't stay charged too.
Not a place were "trying" to save $150 is worth it IMO.
When you realize a fill-up is $160 (or more), the cost of parts
doesn't look so bad.
Old Nov 29, 2011 | 05:59 PM
davidkstyler's Avatar
davidkstyler
One way to check the electrical output is to turn everything on and then see how many volts you are generating. Mine usually runs around 13.5v after the glowplugs turn off. A factory alternator needs to be above idle speed to test, some of the aftermarket units have a smaller pulley and can have a good output at idle.
Old Nov 29, 2011 | 07:36 PM
Rusty Axlerod
Just my opinion(and experience) here but, if I were NOT going to buy an aftermarket Upgrade alternator, I would check locally for a starter/alternator repair shop and get my original repaired. Saves a few bucks and I truly believe you get a better part.
Old Dec 4, 2011 | 01:12 PM
chas111's Avatar
chas111
can a person check voltage with a DMM right at the battery?
Old Dec 4, 2011 | 01:32 PM
davidkstyler
You can check it at the battery or I use these as a quick check in the lighter socket.
Car 12V /24Volt Meter Red Digital Display VOLTAGE GAUGE | eBay
For $0.99 shipped it is almost throwaway
