need advice
Old Nov 27, 2011 | 11:46 PM
crazy horse 69 f100's Avatar
crazy horse 69 f100
need advice
I know this is dumb, but I am trying to get my heater working & here is my problem, on the heater valve under the hood when you put the heater on hot - warm, should it be closed, or open, this is my first old truck, but I have to trace down where my cable is loose. I bought a couple of extra lock tabs & I never got around to getting my heater fixed. I just have trouble laying under the dash for more than a few short minutes. I have owned a lot of 60's muscle cars, but never a truck this old even though it's younger than me. I need to buy some books, because I haven't been able to work since 06 & I forget more everyday, so if anyone could pm me I would really appreciate it, thanks.
marty
Old Nov 28, 2011 | 12:30 AM
Nod's Avatar
Nod
Heat
crazy horse 69 f100,the valve should be in the open position for heat and partially open for warm.
"bowties in the rearview mirror"
Old Nov 28, 2011 | 06:40 AM
tmcalavy's Avatar
tmcalavy
pull the radio...all the dash-end cables are right below it...easier access.
Old Nov 28, 2011 | 10:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I need to buy some books, because I haven't been able to work since 06 & I forget more everyday.
The 1964/72 Ford Truck Parts Catalog is available on a CD from hipoparts.com for about 22 bucks, and...
C3UZ-18495-A .. Cable Controlled Heater Water Valve (Motorcraft YG-133) / Available from Ford.
Applications: 1965/66 F100/1100 / 1967/72 F100/750 / 1963/67 Econoline.
MSRP: $46.16 // FTE sponsor PARTSGUYED.COM price: $27.70.
This heater water valve is notorious for rusting up in the closed/open or partially both positions. It's spliced into the inlet to heater core heater hose.
Old Nov 28, 2011 | 10:59 PM
crazy horse 69 f100
ok thanks all of you. I guess I need to close the valve, because it's leaking when running I thought that was the answer, but just wanted to be 100% sure. I really appreciate the answers thank you all very much.
Old Nov 29, 2011 | 11:40 PM
crazy horse 69 f100
yeah I found a valve at advance auto for 15.53 or close to that, it may be stuck because the cable moves , but the valve doesn't, bought a couple of new lock clip just in case. I also bought a used control panel for the dash off ebay, my letters were unreadable ok everyone thanks I will get it straightened out one day
6t6merc
Jan 30, 2023 01:36 PM
Bear13861
16
Mar 6, 2017 02:21 PM
AxelRipper
30
Dec 11, 2015 07:25 AM
Tuntavern1775
15
Jan 27, 2015 02:54 PM
Schuyles
Feb 15, 2011 09:00 AM
