Heater question
Old Feb 14, 2011 | 11:10 PM
Schuyles's Avatar
Schuyles
Heater question
my core was leaking so I got a new one. I have already taken the box apart and put the new core in, but then decided to try to do it correctly, so here comes the question. I bypassed the core last year, so I don't want to have to hook it up twice.
I saw in an old thread that the seals and stuff would work from this kit:
Classic fORD Bronco Replacement Parts, Gaskets and Seals
Seems like a good idea, as the ones around my core were non-existent.
So, while I wait on that, I realized that I have NO IDEA how this thing works. If the fluid is running through the core all the time, I guess that means I can only ever have heat coming through the vents? The thing I don't understand is, why does the **** say, "pull for heat?" If I don't "pull" the ****, how could cold air come through? And what in the world does that cable (attached to the "pull" ****) move inside that box to cause heat?
It seems to me that turning on 'heat' would mean letting coolant run through the heater core, otherwise, if no coolant was flowing in it, it could be cool air coming in.
Sorry if this is dumb, maybe it's just late. Hopefully someone can set me straight.
Old Feb 15, 2011 | 12:18 AM
Redmanbob's Avatar
Redmanbob
Well if you look down there it's a gate that closes off the heater box. Open it when you want heat to become part of the fan powered ventilation. Unless it still has all it's bells and whistles it's likely the box is always hot but sealed up. Desire heat, open the gate and the fan will draft it. IIRC the lever also controlled a valve under the hood that controlled water flow through the heater core. Mine has been removed and replaced with a manual T valve that must be actuated from under the hood. I leave it open, to keep the crud(soot from building in the core due to lack of operation)
Might also check here,
https://secure25.securewebsession.co...shop/index.htm
Old Feb 15, 2011 | 02:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There are 2 different types of heaters used in these trucks, Deluxe and Economy. Both have the combination "pull for heat" cable and blower switch mounted in the dash panel.
1) The Deluxe heater has two cables mounted to a bracket to the right of the steering column at the bottom of the dash.
One cable opens/closes the damper door that allows fresh air to enter the plenum chamber (heater box).
The other cable opens/closes the heater water valve (C3UZ18495A/Motorcraft YG133). This valve is spliced into the inlet-to heater core heater hose.
2) The Economy heater does not have the two cables or a heater water valve.
Instead, there is a manually operated heater water shut-off valve (C5TZ18495A) located in the same place as the Deluxe's heater water valve.
The C3UZ18495A heater water valve is available from Ford.
MSRP: $38.46 // FTE Ford Dealer Parts Dept sponsor PARTSGUYED.COM price: $23.08.
The C5TZ18495A manually operated shut-off valve is obsolete, but can be found NOS at Ford Dealers/obsolete parts vendors.
Old Feb 15, 2011 | 09:00 AM
Schuyles's Avatar
Schuyles
Thanks for the information, I guess I just have some decisions to make as to how I want to run the setup.
Too bad it's time's like these I think to myself, "just keep driving with no heat...it's easier."
earlybird 2
20
Mar 6, 2018 05:40 PM
Bubba Jones
1978 - 1996 Big Bronco
24
Mar 19, 2014 10:55 PM
Justin's Green Truck
1997 - 2003 F150
Mar 28, 2010 09:12 PM
77'F-150Mudder
17
Dec 7, 2003 02:18 AM
Racerdave
Dec 21, 2002 08:17 PM
