fuel filter sensor?
Old Jan 25, 2009 | 07:41 AM
ckal704's Avatar
ckal704
fuel filter sensor?
Keep getting an intermittent fuel filter warning light on the dash.
I replaced the filter about 8 k miles ago and it lessened the issue, but I'd like to replace the sensor too next time I put in a new filter.
Looking for pic/diagram of sensor and a part number if anyone has one.
Thanks!!
Old Jan 25, 2009 | 11:48 PM
2HI2CU's Avatar
2HI2CU
Here's an older thread on it that helped me out with the part # when mine decided to quit....... https://www.ford-trucks.com/forums/5...ng-switch.html
Old Jan 26, 2009 | 08:02 AM
KevinC.'s Avatar
KevinC.
Thanks!!
This pic thanks to tjbeggs should help.
Old Jan 26, 2009 | 08:03 AM
KevinC.'s Avatar
KevinC.
oops forgot link lol here it is... Engine Sensors pictures from friends & fun photos on webshots
Old Jan 26, 2009 | 08:04 AM
KevinC.'s Avatar
KevinC.
just click where it says engine. i'm not so good at pasting links
Old Jan 26, 2009 | 11:55 AM
Cuda_jim's Avatar
Cuda_jim
PSD part #'s...save it in your bookmarks.
TikiWiki : PSD Part Numbers
Here's some good reading. You can download them... .pdf's
Diesel Technician Society
I you are good at changing the fuel filter (every 10-15K miles) you could skip the sensor just plug the hole with a pipe plug. 1/8 NPT IIRC.
Old Jan 26, 2009 | 04:03 PM
ckal704's Avatar
ckal704
Thanks for the info. I had tried a search, but came up empty. Can't figure out why because I remembered seeing threads on the subject before.
Old Jan 27, 2009 | 06:39 AM
Cuda_jim's Avatar
Cuda_jim
Not sure what you are looking for. It's a vacuum sensor that looks like an oil pressure sender. It measure the vacuum (restriction) in the filter housing. It's a single wire sensor on the very top of the filter housing, drivers side.
The sensor completes the circuit to ground. The only thing that will illuminate the light is a short to ground or a plugged filter. If you unplug it the light will never come on. It could just be that you need a new filter, after 8K miles? and the sensor is OK.
