6.9L Glow plug controller
Old Nov 27, 2011 | 07:06 PM
gmlawnandlandscape's Avatar
gmlawnandlandscape
I have a 6.9 that the glow plug controller broke off and I have to order another one because none of the parts stores around here have one. It broke with some of the threads still visible so I will be able to get the rest out. My question is will the truck still run if I just have the top part thats plugged in tied up??? yes I know I would have to give it a shot of either to get it started.
Thanks for any input
Old Nov 27, 2011 | 07:21 PM
Aune163rd's Avatar
Aune163rd
yes it will still run, i would just convert to a manual push button system...way easier than messing with the automatic controller....
Old Nov 27, 2011 | 07:37 PM
gmlawnandlandscape
Thank you for the advice!
Old Nov 27, 2011 | 08:55 PM
Otahyoni's Avatar
Otahyoni
Be very careful using ether. Theres still a chance the glow plugs could glow some and cause an explosion. I would make sure they have no power if you plan on using ether.
USE VERY LITTLE! Some would say none.
Old Nov 27, 2011 | 09:25 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Will run fine is you can safely get it started...
X2 on best mod, manual glow plugs!
Or if auto plugs are a must, convert to 87+ solid state system. The controller sits at the back of the engine, under the air cleaner assembly.
Old Nov 27, 2011 | 10:13 PM
gmlawnandlandscape
Thanks guys!! I will give it a try tomorrow, it has a block heater but I don't know if it still works or not.
Old Nov 27, 2011 | 10:15 PM
IDIDieselJohn
What year is it??????
If it's 1985.5 or older, DO NOT USE THE BLOCK HEATER! You risk cracking the block!
Your only option would be an inline heater, one you put inline in the heater hoses.
Old Nov 27, 2011 | 10:18 PM
Otahyoni's Avatar
Otahyoni
Theres also one you can put in the lower radiator hose.
The tank type that John is talking about needs to be installed at the lowest point(or close) or it wont work. Follow the directions carefully if you get one.
Old Nov 27, 2011 | 10:21 PM
gmlawnandlandscape
Oh ok, It's a 86. I never used it so I didn't know if it would even work.
Old Nov 27, 2011 | 10:22 PM
IDIDieselJohn
Ok your good if it's an 86.
Old Nov 27, 2011 | 10:24 PM
Otahyoni's Avatar
Otahyoni
If you've never used it i'd keep an eye on it for a bit, maybe look the cord over to make sure its not bare anywhere, but other wise, go ahead and plug 'er in.
Old Nov 27, 2011 | 10:28 PM
gmlawnandlandscape
Thanks guys! I will give it a try in the morning. I have it in my shop so it may start on it's own. I will let you know how it goes
Ricky Kuczmarski
May 2, 2016 08:15 PM
RRranch
Nov 8, 2010 03:23 PM
mesajoejoe
Mar 4, 2008 07:51 PM
Diesel Fiend
Nov 1, 2007 06:34 PM
79man
Dec 1, 2005 06:49 PM
