what kinda headlights do yall have
#31
FWIW Silverstar ultra's are the best headlights i've ever had before, well worth every penny spent.
I think the OP was talking about headlight housings though, not bulbs to improve light output. The bricknose trucks have no lack of output, I laugh whenever I read a thread complaining about it. If you think your bricknose isn't showing you enough road at night borrow a buddy's 1994-2001 Dodge Ram for a week and try not to hit something.
#32
I personally have never owned an 87-91. But I look at parts alot, and I have never seen any aftermarket headlights for that bodystyle. I was pretty much referring to any exterior front end options at all are scarce for the 87-91.
On a side note, you can get an upgraded wire harness that will boost the voltage going to the lamps. Which makes them brighter.
RJM Injection Tech — Headlight Harness
#33
#34
A little history, to explain where I'm coming from: Up until about 1960 or 61 American cars used the front clear parking lights and rear brake lights as turn signals, until the European's separate amber turn signals both front and rear started being adopted in American cars, although some manufacturers have never used amber lenses in the rear. All bulbs were clear, relying on the amber lenses for color. I always assumed the advent of amber-colored bulbs was introduced as a way to get amber turn signals into older cars in the front parking lights.
I look at clear turn signal lenses with amber bulbs as a step backward to the "old days." Not to mention being an added inventory item for bulb manufacturers and retailers. I always thought of amber lenses as a bit of added (attractive) color and class to cars.
I think that it can go either way. Sometimes I kinda want to put my amber lenses back on.
The other afermarket lights a d tail lights I can't stand.
#35
That headlight relay kit is great. We have it on 3 vehicles.
Silverstar bulbs and all other artificially colored super white bulbs are complete junk.
The best bulbs are GE Nighthawk, Sylvania Xtravision, and other increased brightness clear bulbs. The color may not be as white, but there is actually more light output since none of it is filtered out.
#36
#37
I ran across this today. this guy has some clear corners for sale for $30.
https://www.ford-trucks.com/forums/1...150-parts.html
stylin86f150
30
03-26-2010 03:03 PM
