1978 - 1996 Big Bronco
ABS Problems
Old Nov 26, 2011 | 07:12 PM
gener46's Avatar
gener46
ABS Problems
Hi Everyone thanks in advanced. ABS Problems, Long story short I hope. Had new disk rotors press on my hubs and that when it started. On 1<SUP>st</SUP> test drive fled a shudder and brake pedal problem heard noise from brakes and no ABS light or codes. Check everything under the sun and came to conclusion that it was the reluctor ring. Found a article on the net that describe the same thing I fled. Had the shop re-press reluctor ring again making sure it was on right. No evident of damage on ring I think. Re installed hub and this time a different feeling. The brake pedal when down further than it should heard a sound from brake and a ABS light came on. Drove the truck and the brakes work great but still had that light. Try to pull the codes and there were none. The strange part, when you 1<SUP>st</SUP> start and drive the truck there is no light until you hit the brakes you feel the pedal go down and hear a sound and then the light comes on. Drives find after that just have the light. It clears itself until you drive it and then hit the brakes. What do I look for? Is the reluctor ring toast or is the sensor bad? Thanks Gene
Old Nov 26, 2011 | 10:15 PM
Edgethis's Avatar
Edgethis
I doubt the ring is bad, more likely a bad sensor on the knuckle. They are pricey too! Are the brakes all bled/adjusted properly?
Old Nov 27, 2011 | 04:37 AM
gener46's Avatar
gener46
ABS Problem
Thanks for replying. I bleed did the brakes, but I didn't do any maintance to the rear. It's just kind of strange that it happen when I change out the rotors and it was fine before with the old rotors. Oh and also when I had them re press the ring cause I thought it wasn't on even and when I re assemble it, it acted differant after that. Thanks Gene
Old Dec 31, 2011 | 03:49 PM
gener46's Avatar
gener46
Just to let everyone know I found the problem with my ABS system. I found an article on the internet that talk about just what I had wrong. There is an air gap between the ABS sensor ring and the ABS sensor itself. If it is too great you will have problems. I took all the dimension I needed and made adjustments to the ring itself. Problem solved. If some anyone need this info I can provide a copy and maybe the link too. Thanks to all who help me on this matter. fficeffice" /><O></O>
Old Dec 31, 2011 | 05:22 PM
Edgethis's Avatar
Edgethis
Please provide us the link so that others who may search for this issue can find it easier.
Old Jan 3, 2012 | 04:25 PM
deadeyedevon's Avatar
deadeyedevon
please share the knowledge. Im haveing the same problem, i just pulled the abs fuse to temp. eliminate the prohblem.
Old Jan 5, 2012 | 06:18 PM
jimbo285's Avatar
jimbo285
I dont understand why an air gap would make the pedal go down further and make a noise. Maybe the sensor contacted the hub? Maybe that's why the airgap was too great. I didn't know there was an adjustment available on the sensors. Last time i removed mine, it just goes back in the hole and got tightened down.
runsky69
2004 - 2008 F150
Sep 5, 2016 09:33 AM
mikulskn
Jun 26, 2013 11:23 PM
BB 5.8
Mar 14, 2005 10:01 AM
Staceman
Aerostar
Feb 26, 2002 09:57 PM
