So, last night I jumped in my truck and when i turned the lights on, my entire dash lit up (normal) except for my digital odometer screen (lower right hand corner). There was a small light at the bottom of the rectangle, but nothing was illuminating the screen.
I screwed around with the dimmer switch, interior lights, ACC and other Ignition Functions but couldn't get it to work again.
I did a search for "Dash" and "Dash Lights", but couldn't find anything.
Has anyone ever had this happen or have any ideas of cause and fix?
I got it used from a Fleet Company. So i'm at 110k already. No warranty. I could have them look at it though...maybe they can shine some light (pun intended) on the situation.
I suspect you've dislodged a connector on the back of the cluster. If the screen isn't "lighting up", it's not a burned out bulb or something - the screen isn't getting power.
Perhaps you should consider keeping all 4 tires on the ground?
He said "jumped in my truck". That's pretty clear to me. The truck didn't jump nor was it jump-started. He got into his truck. If he's not supposed to do that I don't know what our trucks are for.
