Identify this motor
Old Nov 26, 2011 | 12:25 PM
clinkfield's Avatar
clinkfield
Identify this motor
Can anyone tell me what motor this is? What about the carb?
It is a 1964 F100.
Does anyone know if they came with a wood floor in the bed? Or was that done later?
http://photobucket.com/mustardF100
Old Nov 26, 2011 | 12:55 PM
bunchoftrucks's Avatar
bunchoftrucks
It looks like a 223 which would be an J engine code on the door plate. As far as the carb no idea. Wood bed floors were in flare/step side trucks. Hope this helps.
Old Nov 26, 2011 | 01:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by clinkfield
Can anyone tell me what motor this is? What about the carb? It is a 1964 F100.
The 4th digit of the VIN is the engine code:
J = 223 1V I-6 (standard equipment) / B = 262 1V I-6 (optional).
The triangular ID carb tag was bolted to the airhorn, If missing, look on the base of the carb for a stamped ID number, like this example: C3TF-AA.
Flaresides had wood bed floors, originally it was painted body color.
Old Nov 26, 2011 | 03:39 PM
clinkfield's Avatar
clinkfield
This is not a step side. But it has a wood floor in the bed. Would it be a good guess that the original floor rotted and was replaced with wood?
Old Nov 26, 2011 | 05:05 PM
jowilker's Avatar
jowilker
The truck in your album link above came with a metal floor.
John
Old Nov 26, 2011 | 05:50 PM
bunchoftrucks
Probably was replaced in the past. It would look pretty cool with some nicely stained hardwood and stainless strips and be custom too!
Old Nov 27, 2011 | 11:56 AM
clinkfield's Avatar
clinkfield
The tag on the door says:
Warranty number: F10BN552298
WB Color Body
114 K 481 A 12
The engine has these letters: C2TE-6015-A
Is the "Warranty number" the same as the VIN?
Old Nov 27, 2011 | 03:56 PM
NumberDummy
VIN: F10BN552298 / 114 K 481 A 12
The casting number on the engine block: C2TE-6015-A
F10 = F100 2WD
B = 262 1V I-6 (optional over the 223 1V I-6).
N = Norfolk VA Assembly Plant.
552298 = 1964, assembled June 1964.
114" Wheelbase.
K = Bengal Tan.
A = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
481: 4 = Light Beige Crush Vinyl & Light Beige Rib Vinyl / 81 = 81A Standard Cab.
12 = Ford 9" Rear Axle / 3.89-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
Casting numbers are foundry marks, cannot be cross referenced to Ford part numbers.
Old Dec 1, 2011 | 08:07 PM
graflexmaster's Avatar
graflexmaster
X2 on the above info...... but the carb looks like a holly single bbl from a late 60's 200 straight six... as it looks the same as one I had on a 68 stang with a 200 many years ago.
modularF100
Sep 3, 2011 10:20 PM
jay3403
1961 - 1963 F100 Unibody
27
Apr 11, 2009 12:40 PM
cujo8
Oct 9, 2006 07:41 AM
restoringmy46
1947 and Older Ford Trucks
Jan 21, 2005 11:22 PM
cateringcook
Dec 3, 2003 08:21 AM
