46 ford bed question?
Old Jan 21, 2005 | 02:55 AM
restoringmy46's Avatar
restoringmy46
Went to take the bed off my truck today. And when you look under the truck you can see the old rotted wood, and I expected that. But on top of the wood there is a thin piece of steel, so thin you can see where the metal strips imprinted in it. Is this something that it came with or what. There is a very good example on ebay motors right now of what I'm talking about. Look under 1947 ford truck to see it. I don't think this metal is supposed to be there. But when I seen this truck the same way, well I'm second quessing myself now. Can anyone help me with this?
Old Jan 21, 2005 | 08:19 AM
46fordtruck's Avatar
46fordtruck
Sounds like the bed floor. These trucks had the bed floor that consisted of a hardwood sub floor, which is visible from under the bed, and a stamped sheetmetal covering that had the skid strips stamped right into it that was placed over it. Most guys will usually use one of those bed kits and leave just a nice hardwood floor and not replace the sheetmetal covering. The sheetmetal tends to rust out, and it's a big job to replace the part.
Old Jan 21, 2005 | 09:55 AM
mtflat's Avatar
mtflat
You can buy the sheetmetal bed floor from several sources including Mack Products of Moberly, MO. They run approx $325 plus shpg. That's the biggest reason I left the wood show when I rebuilt my '48 - plus I love the look of natural wood.
Old Jan 21, 2005 | 01:37 PM
restoringmy46
I think I'll go with the wood floor to. I like that look better. So I quess all you do is cut the steel floor out and grind the edge off the bottom of the bed side. Or do you guys have a better idea how to seperate the steel floor from the bed. I'm up for any ideas. Thanks again for the info to. I didn't know the beds were made like that. I figured the bed floor was like my 48 is. Just wood, or should I say "rotten wood".
Old Jan 21, 2005 | 05:14 PM
mtflat's Avatar
mtflat
I just took an air chisel and slid the cutting tip along the bedsides. The spot welds popped pretty easy. The route you're suggesting would work too but might show when you're finished.
The 42 thru mid-50 all had the metal floor. In mid-50 they went back to wood. If you have a 48 it had sheetmetal originally.
Old Jan 21, 2005 | 09:35 PM
46yblock's Avatar
46yblock
Restoring, if you don't have an air chisel get one or borrow one as suggested by mtflat. I just recently cut out the floor with a 4 1/2 inch X 1/16 inch grinder. Then for the remaining side strips tried a cold chisel and hammer. It was distorting the outside panel, so went back to the 4 1/2 inch grinder and carefully ground all of the many spot welds just short of breakthrough. Then with hammer and sharp wood chisel finished cutting the welds. It was long and tedious, and of coarse ruined the chisel.
Old Jan 21, 2005 | 11:22 PM
restoringmy46
I learn somthing new evertime I get on here. I didn't know they came with a metal floor over wood. But this is my first time redoing a old truck. I've always had cars. I think I'll go ahead and cut the floor out with a grinder as close as I can to the bed sides and then use a air chisel for the rest of it.
ufvj217
Oct 9, 2014 12:19 PM
1950FordF1
Sep 19, 2014 10:00 AM
Herbiehusker
20
Oct 21, 2009 10:22 AM
imlowr2
22
Aug 30, 2005 10:03 AM
