Truck Shut Off
Old Aug 26, 2005 | 08:10 AM
Hi-psi's Avatar
Hi-psi
Truck Shut Off
Guys,
Had my new (to me) 2000 F250, Powerstroke for about 1 1/2 months now with no issues. Love the truck. Current mileage is about 203k. Was on the way to work this morning in some stop and go traffic, and the truck just shut off on me. Stopped, put it in park, and it fired right back up. Had no other issues or weird behaviour after that. As for when it shut off, I had been lightly accelerating, then taken my foot off the accelerator, and just as I began to apply the brakes is when it shut off. I'm a little new to diesels, but the behaviour/conditions in which is shut off in my experience with gasoline engines is if something went wrong with the IAC (Idle Air Control) valve for a second. Be it just a momentary hiccup, or it stuck and didn't open, causing the engine to die.
Thoughts?
Any help is greatly appreciated.
Old Aug 26, 2005 | 10:29 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You don't have an IAC on your PSD. It's probably the CMP. (camshaft position sensor)
Old Aug 26, 2005 | 10:37 AM
Hi-psi's Avatar
Hi-psi
Did you mean the CPS (cam position sensor)?
Old Aug 26, 2005 | 10:43 AM
cookie88's Avatar
cookie88
FTE Emeritus
That's what I said. Ford calls it a CMP sensor and International calls it a CAMP sensor. Nobody except people on the forums calls it a CPS.
Old Aug 26, 2005 | 10:48 AM
Hi-psi's Avatar
Hi-psi
Gotcha. CPS is what I have always heard it reffered to as. Even on other vehicles. Either way, I just ordered one.
Old Aug 26, 2005 | 10:52 AM
cookie88's Avatar
cookie88
FTE Emeritus
Right, but at the dealer CPS will probably get you a crankshaft position sensor.
Where did you order it? The International dealer is normally quite a bit cheaper than the Ford dealer on this, and most other common engine parts.
Old Aug 26, 2005 | 11:32 AM
Hi-psi's Avatar
Hi-psi
$55 shipped, new in the bag off eBay.
Old Aug 26, 2005 | 11:55 AM
cookie88's Avatar
cookie88
FTE Emeritus
Wow, great deal.
