Acceleration problem
Old Jul 8, 2007 | 09:30 AM
Camper1's Avatar
Camper1
Does anyone have any idea why after i start up my 2002 7.3 and put in gear and step on the throttle the engine will not rev up and want to move. Other time i can get in it, and start it up, put it in gear, and away we go no problem.
The truck starts just fine.
The other problem is once in a while while driving down the hwy the engine will shut down and come back right back on.
These two thing are driving me nuts.
Old Jul 8, 2007 | 09:33 AM
Green_Dually's Avatar
Green_Dually
This sounds like the classic cps problem.Dealer has them for 25 or so bucks.
This sounds like you TPS is on its way out.
If im wrong other gurus will chime in.
Old Jul 8, 2007 | 09:52 AM
Camper1's Avatar
Camper1
i got two annswers. is it cps or tps and what is a cps or tps.
Thanks
Old Jul 8, 2007 | 09:59 AM
Uzumati's Avatar
Uzumati
Throttle position sensor - TPS
Idle Validation Switch - IVS
Cam Position Sensor - CPS F7TZ-12K073-B at www.powerstrokeshop.com
I am with Eric the no rev sounds like a TPS/IVS problem and the cutouts sound like CPS.
Old Jul 8, 2007 | 10:04 AM
Camper1's Avatar
Camper1
Brother had problems with the cps on his 7.3 but when it went out the truck would't start and when he did get it started and made it home it ran rough and couldn't get any speed out of it.
Could the cut out be caused bu the electronic module?
Thank you for the information.
Old Jul 8, 2007 | 10:24 AM
Uzumati's Avatar
Uzumati
Which Electronic Module?
The TPS can act like a failing CPS sometimes since its input can cause a PCM reset if it gets out of range bad enough.
