problems with f-150 back up camera
I have a 2011 F-150 Super Crew and have had to replace the back up camera due to a malfunction. Once the dealer replaced it under warranty I was no longer able to get all the options that the previous camera had. Since then the 2nd camera went bad and I just had it replaced again. This new camera still is missing 2 of the options the original camera had. The dealer now tells me that they must have been deleted off the software on the replacement cameras. They were unable to verify that through Ford though. Does anyone have any suggestions?
my camera also acts up. I can turn on the guidelines and everything works fine till you turn off the truck. When you jump in to go again and put it in reverse the guidelines have disappeared and when I go in and check the computer again they show as being turned off. Have not taken it in yet but will have them check it out next oil change.
ThirdsACharm
Car/truck Buying Advice
10-15-2011 05:25 PM
