Speedometer questions
Old Nov 24, 2011 | 07:40 PM
quality1construction's Avatar
My sppedometer has quit working. This problem has been coming for a while now. It used to stop, then I'd pull over to a complete stop and pull back out and it would start back up again. Now it doesn't start hardly ever. I was on a 400 mile trip the other day and it started working about 100 miles in, then when I came to a stop it quit again. I changed the vss on the rear before, flushed out the fluid in the rear, still no help. Speed Ring gear wore out? Thoughts? Hope y'all had a great Thanksgiving today!!
Old Nov 24, 2011 | 07:45 PM
woodnthings's Avatar
woodnthings
There is also another sensor on the output of the transmission, that could also be the problem. Do you have any way of getting someone with AE to hook-up to your rig? That would be an easy way to check it out.
Old Nov 24, 2011 | 08:00 PM
I am not sure if there is anyone around here or not. What would the other sensor be called? Never heard of it.
Old Nov 24, 2011 | 08:11 PM
woodnthings
It is the output shaft speed sensor. You may also have problems with the ABS module or the instrument cluster too.
Old Nov 24, 2011 | 09:16 PM
Anyone have a part number for this? I assume its in the transfer case?
Old Nov 24, 2011 | 10:45 PM
woodnthings
It is on the transmission.
Look at this picture, there are two sensors with red caps on them, the forward one is the input speed sensor, the other is the output, they are the same sensor.
Here is the parts diagram showing them.
Old Nov 24, 2011 | 11:21 PM
Mine is the 6spd manual 4x4, is it still on the rear of the trans or on the transfer case? Thanks
Old Nov 24, 2011 | 11:37 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Ken,
I think those two sensors are the same part number except for automatics with PTO abilities. Then the forward sensor is a different length. The diagram you posted shows the length of the input sensor depending on the version you have.
Old Nov 25, 2011 | 12:13 AM
My question is do the automatics and the 6 spd maunal use the same sensors? I have the 6spd, not the automatric. Thanks for the help.
Ryan313
Dec 27, 2024 06:31 PM
MustangGT221
Nov 7, 2012 08:49 AM
kjf-250
Jan 19, 2010 09:17 PM
pat_da_man
Oct 25, 2009 08:52 PM
djtech
Jul 20, 2006 08:32 PM
