clutch pedal went out
on
Well that fluid went somewhere. Look around to see what's leaking. If you let the fluid get low enough to suck air into the master cyl you may need to bleed it. Also make sure the pedal is still connected to the MC under the dash. If it comes unhooked the pedal will go to the floor and stick there. There is a plastic bushing that keeps them connected, available in the HELP! section at Autozone and other auto parts stores.
Obviously you should bench-bleed the master before installing it. Put it in a vise and push the piston with a big screwdriver.
Slave should cost about $50-$80. It's the installation that's a pain, as I'm sure you're painfully aware- may take all day.
Bleeding the system once it's installed is hard on these. Read the forums for some good suggestions.
After you get the master out, it's pretty easy to take apart and find out if it has bad o-rings, so do that first before you got to the trouble of dropping your tranny.
Looks like yet another "my cheap-*** made in china after aftermarket slave cylinder failed after only X months!" thread.
I don't know where these things are coming from, but every couple of weeks there is a thread in this forum. Seriously, do a search. There are a ton of them in here.
The solution is to buy a motorcraft slave cylinder. The made in china junk just doesn't last. I think they're $160 or so, they're not terribly expensive... but it sure beats dropping your transmission every 6-8 months to replace another $60 failed one.
Tyson82
13
02-16-2009 06:14 PM
MrRealityman
06-23-2007 09:09 AM
badford86
05-17-2004 03:18 PM
