clutch pedal went out
Old 11-24-2011, 07:42 AM
jhobbins's Avatar
jhobbins
jhobbins is offline
My clutch pedal on my 93 f 150 goes straight to the floor and doesn't come back up. The slave cylinder was replaced 8 months ago so I don't think that's the problem but I'm not sure. Anyone elseever have a simliar problem?
Old 11-24-2011, 07:59 AM
frederic's Avatar
frederic
frederic is offline
Yes, and in my case it turned out to be the master cylinder. The seals on the piston were shot and fluid was getting past, allowing the pedal to move without actuating the slave cylinder.
Old 11-24-2011, 08:13 AM
jhobbins's Avatar
jhobbins
jhobbins is offline
yeah I was thinking my master cylinder might be shot, I've been having to refill my brake fluid reservoir about twice a month for a while now
Old 11-24-2011, 08:23 AM
bashby's Avatar
bashby
bashby is offline
Well that fluid went somewhere. Look around to see what's leaking. If you let the fluid get low enough to suck air into the master cyl you may need to bleed it. Also make sure the pedal is still connected to the MC under the dash. If it comes unhooked the pedal will go to the floor and stick there. There is a plastic bushing that keeps them connected, available in the HELP! section at Autozone and other auto parts stores.
Old 11-26-2011, 06:23 PM
jhobbins's Avatar
jhobbins
jhobbins is offline
I was told if a certain hose is leaking, the master cylinder can burn fluid. Also im pretty sure the pedal is still attatched because it started losing pressure and stopped wrking over a 2 day period
Old 11-29-2011, 04:05 AM
jhobbins's Avatar
jhobbins
jhobbins is offline
how do i bleed the master?
Old 12-10-2011, 06:26 PM
jhobbins's Avatar
jhobbins
jhobbins is offline
if it is the slave cylinder, how much does it cost to replace it?
Old 12-11-2011, 01:14 PM
732t37's Avatar
732t37
732t37 is offline
Obviously you should bench-bleed the master before installing it. Put it in a vise and push the piston with a big screwdriver.
Slave should cost about $50-$80. It's the installation that's a pain, as I'm sure you're painfully aware- may take all day.
Bleeding the system once it's installed is hard on these. Read the forums for some good suggestions.
After you get the master out, it's pretty easy to take apart and find out if it has bad o-rings, so do that first before you got to the trouble of dropping your tranny.
Old 12-11-2011, 01:28 PM
andym's Avatar
andym
andym is offline
DING! DING! DING!
Looks like yet another "my cheap-*** made in china after aftermarket slave cylinder failed after only X months!" thread.
I don't know where these things are coming from, but every couple of weeks there is a thread in this forum. Seriously, do a search. There are a ton of them in here.
The solution is to buy a motorcraft slave cylinder. The made in china junk just doesn't last. I think they're $160 or so, they're not terribly expensive... but it sure beats dropping your transmission every 6-8 months to replace another $60 failed one.
mapache
01-08-2016 07:19 PM
Tyson82
13
02-16-2009 06:14 PM
MrRealityman
06-23-2007 09:09 AM
mannyj
02-07-2005 12:36 PM
badford86
05-17-2004 03:18 PM
Quick Reply: clutch pedal went out
