Best affordable hei distributor
#46
I know this is off topic. But... Don't sell it. Find another way to deal with whatever issue you are having. I sold my 71 camper special beater over 6 years ago I still kick myself in the but for that one.
Either way thanks all for the kind words on the engine bay. Alot of work went into that sucker. Including removing no less than 60 feet of wire. I filled up a whole trash can cleaning up previous owners bull$$&@.
#49
Yes,11.9v with the key on and 13.7v with truck running.Yeah i have just allways used a test light now i got a multi meter im checking every thing.I am just not fimilar with what there suppose to read and where but with the help off all you guys this forum is awsome.All the ding dongs up here in AK can hardly tie there shoe's at the shade tree shops.So there no help. Some of the jerry rigging you see is unbelievable.As said in previous posts.Its nice to see good craftsmanship.Ferm believer in doing it right the first time.Thanks for clearing all this up for me guys.I with post pic of the finished product.My motor dont Quite look is immaculate as co 425 LOL
#50
In one pic you can see the little tab that needs to be pryed back and in the other pic you can see how it locks into the spade connector. You might also try warming it up a bit with either a hair dryer or a heat gun to make the plastic a little less brittle.
Hope these help.
#51
I'm sure you would have or already have figured it out, but I got some pics from another member (Thanks John) that might help.
Hope these help.
Hope these help.
#52
#53
#54
The only way for it to clear, is to build one. Machine a mounting flange and have a piece of pipe come off it at a 45* angle.
#55
I do have the housing with the flat spot on it. I would need to clearance it at least another 1/8 just to get the body of the dizzy to clear. Then, I'd have to take off another 3/16 to 1/4 just for the cap to clear. Not enough meat on the housing to do that.
#56
Finally got my hei installed and it runs better then ever.Timing set 12 BTDC and wow im am sold on the snap and the way this thing lights off.Even at -20 below this morning,I barely touch the key and boom.I will post Pictures when I get the intake oil leak fixed and motor washed up here soon.I have to say though 14" air cleaner wont work.Other then that no clearence issues.
#57
Heh, Im sorry for laughing but I find it silly that you had to buy a great distributor for $47 bucks, it must be great quality! And it doesn't fit without using a specific thermostat housing that needs grinding to clear that big dumb chevy cap, with known issues from years ago.
Not to mention the wiring problems, not huge issues, but just sayin!
The ONLY reason it works good is because of the actual HEI module, which can be hidden, and kept in a cooler place with heat sinks, which chevy never did do(seems I remember the general even suggesting moving the HEI module away from the dizzy, with a heat sink). Sure it worked, but what does sensitive electronics hate? Heat and Vibration...
I'll stick to my factory Ford adjustable distributor-centrifugal and vacuum, with proper cap and wires and magnetic pickup. They are adjustable, and do not require grinding to fit. Not to mention proper ignition lead fitment, and ease of service.
maverick600
04-27-2014 04:50 PM
HoustonGuy
04-07-2014 05:46 PM
LedheadELH
04-02-2007 11:18 AM
