Ignition dying out maybe??
Old Mar 29, 2007 | 09:15 AM
LedheadELH's Avatar
LedheadELH
I put some junk 360 I got for free in my bronco as a temporary motor, it had a points distributor as it should, but I had another FE dizzy that I pulled apart, and put duraspark guts in instead of the points. I put it in the 360 and it made a world of difference. It ran much smoother, and much more responsive. When it is cold it's MUCH easier to drive too. My problem is that after running it for like 20 minutes down the road, it goes through these spells where the ignition will shut off for a quick second, then work for a couple seconds, then shut off again and so on. it will do this for miles. Then I pull over and shut'er down, turn everything off. I wait a minute or two and start back up, and continue down the raod and everything is fine....but only for another 5-8 miles or so then it does it again. It's like something in the duraspark module is heating up, and shorting out, or shuting off.
BTW, brand new coil(for the durasprk ignition, the points coil will not work w/ elec. ign), Brand new module, I have good constant power to my coil.....so I'm lost here, unless I just got a bad module????
Old Mar 29, 2007 | 11:44 AM
1975Ford's Avatar
1975Ford
What is the voltage going to the coil when the key is in the "ON" position?
Does the positive wire running to coil when the key is in the "ON" position have a ballast resistor or a resistor wire?
Here are the electrical test for the Duraspark Ignition and Ilustation chart:
https://www.ford-trucks.com/user_gal...=94669&width=0
https://www.ford-trucks.com/user_gal...=94668&width=0
Here are a few extra electrical checks.
Make sure the engine intake has a good ground. The ground cable for intake is located at rear of intake and is mounted to cab.
Make sure the distributor housing is grounding properly. New paint on distributor bracket can make for improper grounding.
Old Mar 31, 2007 | 08:44 AM
LedheadELH's Avatar
LedheadELH
Should my Bronco have a ballast resistor, or something? it originally came w/ the duraspark ignition, so I thought it would love it, but I never had this problem running points. I think because the points use less juice to operate. I cannot see any type of resistor in the circuit unless it is inside the truck, under the dash. Nothing is painted on this motor.....it was a free junk motor....if it blew up tomorrow I wouldn't be sad one bit.
Old Mar 31, 2007 | 10:06 AM
Hypoid's Avatar
Hypoid
The hot wire to the coil IS the resistor. With that in place you should have around 9V at the coil while running.
Old Mar 31, 2007 | 11:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D7AZ-12250-A .. Resistor Wire~Coil to Ignition (Motorcraft DY-213) 49"-length color coded red with green stripes. All vehicles from this vintage have one.
Old Apr 1, 2007 | 07:55 AM
LedheadELH's Avatar
LedheadELH
where does the other end of the wire go to? the end that's NOT on the coil.
I'm not using the factory wiring, because I changed it to run points for the past couple years. so this time it's like I changed a points vehicle like an older one, and converted it to duraspark. The 2-wire plug from the wirewall for the module was never touched, but I ran my own coil wire that goes to a switch, so I could have the key on, and not burn out my points if I ever needed to.
I want to say that the wire I used to go to the switch, is the original coil wire.
So if I were to ditch the resistor wire, would that mess up the coil? Also I have always been under the impression that a points coil uses less volts than the electronic ign. one, but I never had problems w/ the points at all??
Old Apr 2, 2007 | 10:23 AM
1975Ford's Avatar
1975Ford
The positive wire to coil from switch should have a resistor wire.
Try Napa Part number Echlin ICR22, the resistor should give the coil positive power of about 8.5 volts.
http://www.dmauto.com/web/dmauto/Catalog/NAPA_ECAT/search/-/icr22/
click on "view other vehicles this part fits" for the application chart.
What is the voltage at coil with the Key "ON"?
Old Apr 2, 2007 | 11:18 AM
LedheadELH's Avatar
LedheadELH
I don't have a meter here at the house, but I'll check voltages and resistances tomorrow maybe. Hopefully that will give me some idea what's goin' on.
Rulebreaker
Electrical Systems/Wiring
32
Sep 25, 2016 12:24 PM
danford1
Oct 10, 2010 09:34 PM
79F-1504x4
May 28, 2010 09:39 PM
BobcatGuy
Feb 19, 2007 10:41 AM
jwtaylor
43
Nov 23, 2004 09:30 AM
