Rumble / shudder
Old Nov 23, 2011 | 08:49 PM
retnavhmc's Avatar
retnavhmc
Rumble / shudder
Just rejoined this Ford gang after years absence. Used to own "The Muny Pit", a '79 F-150 4WD monster with a '69 429... constantly breaking something. Anyway, back in search of ideas where to look on my '08 F-150 XLT 4WD with a 5.4, 83,000 miles. Searched the search bar for my title and found a post on an '00 Expedition describing similar issue than mine... for about 6 months now when I accelerate either from stop or a crawl; forward or reverse; more so when turning, but does do it wheels straight - upon inital acceleration I have this horendous rumble / shudder in the truck, like the grinding metal bearing sound/feeling felt when the pinion bearing went out on my '79 (only felt it seconds before the 9" rear pumpkin exploded). Once rolling it stops. I have checked all wheel bearings.. I have check all the suspension joints... everything looks fine, no obvious issues. The only suspension mod I've done is a 1.5" leveling kit when brand new. On the Expedition two replys suggested changing the transmission/transfer case fluids claiming it cured thier vehicles, but no response as to if the guy tried this and/or if this worked for the initial poster. Any ideas?
Old Nov 27, 2011 | 12:48 AM
Hendog's Avatar
Hendog
I had a shudder from the rear end, particularly from a stop and when turning. It turned out to be a clutch pack in the rear differential. My warranty covered it.
BTW, it's a 5.4L 4x4 with 3.73 limited slip diff.
Old Nov 27, 2011 | 06:57 AM
MCDavis's Avatar
MCDavis
Sounds like it could be a ring gear issue or a limited slip clutch pack issue. That's whereas I would start at least.
Old Nov 27, 2011 | 11:50 AM
twbtr's Avatar
twbtr
Definatly rear end clutch bearings, assuming you has a limited slip rear axel, if you arent covered under warrenty still i highly recommend you try draining your rear axel fluid, and refilling with two bottles of motorcraft friction modifier in addition to the rear end fluid as opposed to just one, this fixed the problem in mine and i havent had a problem since (limited slip still functions correctly), this is a much cheaper solution than having the clutch packs replaced.
Old Jan 1, 2012 | 11:29 AM
BF750's Avatar
BF750
ditto on the rear clutch pack!
Previous owner may have had it changed and did not add the friction modifier which is a must.
Old Jan 4, 2012 | 08:34 AM
BF750's Avatar
BF750
TxBoi84
2009 - 2014 F150
Jun 7, 2018 07:05 PM
kbalz
1997 - 2003 F150
Mar 17, 2013 10:11 PM
Reefmonster
17
Sep 23, 2011 07:05 PM
WhiteNight
2004 - 2008 F150
Mar 27, 2005 12:35 AM
Heritage___150
1997 - 2003 F150
Mar 30, 2004 08:56 PM
