Air pressure??
Old Nov 25, 2011 | 06:10 AM
  #31
bulla's Avatar
bulla
I'm running 285's and make sure I keep em rotated. So no I haven't had any strange wear patterns such as chop or anything like that. Now I did have an alinement shop spend lots of time on this thing after I changed my ball joints. The shop I bring it to does it all by hand and does a jam up job. I know for a fact we went thru 6-7 cam bushings till he had it dead on. The plus is I was down in the pit with em the whole time and he would show me where it was off and adjusted accordingly. This was after the shop that mounted the tires from said there was nothing wrong with my alignment.
Old Nov 25, 2011 | 04:59 PM
  #32
Supercab's Avatar
Supercab
Wink
Originally Posted by twags6
I get that on my front tires too. Its called heel and toe wear. I'm trying to find a good article on it.
EDIT:
Bridgestone Commercial Truck Tires Last picture on the page
Kal Tire - Tire Wear Conditions Look for "heel/toe wear" title. Nice page on tire wear including pictures.
Thanks for this! I just about 3k miles ago had mine alligned at a BIG TRUCK tire place that has been in business here in town for nearly 70 years-they put a shim in one side, and said everything was nice and tight otherwise, still my tires wear like this!!
I have asked before and looked on the net for allignment specs from the EARLY '99s to toe LATE '99s up and cannot decern anything-mine is 2wd btw.
I am getting really tired of rotating every 2.5k miles to try & avoid this irregular wear.
Can it not be adjusted so it won't destroy my tires??
Old Nov 26, 2011 | 03:25 AM
  #33
twags6's Avatar
twags6
I think this type of wear is more in the design of the tire tread then alignment. Are yours wearing that much? Mine get the saw tooth shape to them, but it wears smooth when I rotate them and looks like a regular tire again.
Old Nov 26, 2011 | 06:20 AM
  #34
bulla's Avatar
bulla
Looked at my door sticker finally and sure enough it calls for 65# front and 60# rear. Yesterday I checked the pressure and compared the wear. I decided to keep 70psi up front and drop the rear to 50psi. Other than that these destinations are doing great!
Old Nov 26, 2011 | 10:08 AM
  #35
kawcrasher's Avatar
kawcrasher
Here is some more info on loads. http://www.goodyear.com/truck/pdf/edb_loads.pdf
The tire and rim association yearbook has complete data on size/load/psi. You may be able to find a tire shop that has one and get it off them when they pick up a new one. They are close to 100 bucks new.
Old Nov 26, 2011 | 12:13 PM
  #36
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Originally Posted by DemonRace6
same as Steve_250, max psi on all 4
x3
I've got my Audi when I want a smooth ride. I'm not trying to knock fillings loose, I just prefer them aired up fully, so long as the tires aren't wearing unevely.
RussEx
Apr 30, 2014 03:39 PM
mcjones44us
Jun 1, 2009 11:24 AM
marspec
Jun 18, 2007 10:26 AM
tlb
Oct 17, 2005 11:43 AM
zr440man
Jun 30, 2005 09:49 PM
