Ex wandering
Old Nov 22, 2011 | 07:21 AM
Racin07jason's Avatar
Racin07jason
Ex wandering
I just purchased a used 2004 ex 79k on it all stock. I have two questions. The first one is it wanders back and forth while driving down the road. I checked pressures and adjusted to specs and it seemed to help but it still does it. The second is i noticed some black soot around turbo connections, is this normal? The good thing is i purchased an almost bumper to bumper extened warranty on the vehicle.
Thanks
Old Nov 22, 2011 | 10:23 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Congrats on the new truck!
When you say the "turbo connections" are you referring to the exhaust or the up-pipes?
The wandering can be cured by swapping in Super duty springs. They ride stiffer and support the truck better than the stock, soft Excursion springs.
https://www.ford-trucks.com/forums/5...-finished.html
https://www.ford-trucks.com/forums/1...vs-c-code.html
https://www.ford-trucks.com/forums/9...questions.html
Old Nov 22, 2011 | 11:45 AM
Racin07jason
Thanks.
The black soot is near the rubber boots. I believe it's the up pipes. I can check tonight to make sure.
I will look into getting the stiffer shocks.
Thanks for your help!!!
Old Nov 22, 2011 | 11:47 AM
Racin07jason
Stiffer springs
Old Nov 22, 2011 | 12:24 PM
Toreador_Diesel
In that case, just grab the proper socket and tighten them. Over time they get loose and leak cuasing low boost pressures and low fuel economy.
Old Nov 22, 2011 | 12:29 PM
Racin07jason
Thanks again for the help. Greatly appreaciated!!!
Old Nov 22, 2011 | 12:59 PM
aero993's Avatar
aero993
Wandering could also be cause by a loose steering box. Use the search function to find existing threads.
Old Nov 22, 2011 | 08:48 PM
1 Excursion camper's Avatar
1 Excursion camper
No, not stiffer shocks. Stiffer springs. With that out of the way the biggest fix for getting rid of the wandering is the installation of a rear sway bar (on the axle). Mine wandered so much I almost traded it after I bought it, it was that bad! Then I found this site and the wandering issues everyone had. I installed a Hellwig rear sway bar and that cured my wandering.
Good luck!
Old Nov 22, 2011 | 10:38 PM
Stewart_H's Avatar
Stewart_H
Click on the following link and prepare for information overload! You'll have hours of reading to keep you busy.
Steering Wander Compilation Thread and 4x4 Spring Information
Stewart
Old Nov 23, 2011 | 06:28 AM
Racin07jason
Thanks everyone for the info.
Jason
unleashd
Feb 2, 2018 06:33 PM
SwaintaN
Dec 23, 2014 12:09 PM
honeyb
Sep 30, 2008 11:49 PM
Pickupman2004
May 8, 2008 08:05 PM
ghunt
23
Nov 28, 2007 08:17 PM
