d-ring o-ring
Old Nov 21, 2011 | 06:34 PM
BLADE35's Avatar
BLADE35
Originally Posted by dukie1877
I went and got all new OEM filters today from Ford and a new fuel and oil cap. 70 bucks for that little plastic fuel cap and only 28 for the big oil cap what's up with that
should have let them keep the fuel cap only thing you have to watch on the fuel fiters is the filters themselves theres no diffrent cap that I know of
Its the oil cap thats critical
Does the new oil cap look diffrent than what you already have
hope the new oil cap and filter doeas the trick
Old Nov 21, 2011 | 08:13 PM
dukie1877's Avatar
dukie1877
n they went right back in and I re lubed the orings before I put the rail in and torqued all the bolts so they are to proper torque specs. We are now rolling with a OEM oil filter and oil filter cap and I am going to change all the fuel filters again back to oem once I run it a little bit to mae sure the old ones catch any gunk. I installed the new oil filter and cranked on it again for another minute or so and still 29-33 icp unplugged the icp and still no start. I cant hear a leak after I turn off the key and everything sounds normal. So I think ill order the o rings just to have them here just incase. any thoughts?
Old Nov 21, 2011 | 08:34 PM
bismic's Avatar
bismic
Originally Posted by amdriven2liv
These look like the International and Ford Parts numbers
International 1843682C91
Not sure what this number is----- CM5055,
Ford 3C3Z9229AA
Did a search on this ^^^number. Can get it cheaper, try your local parts house to cross reference it, see what they say.
The part # 1843682C91 does not contain the HPO d-rings in the injectors. For that you need:
Alliant Power Injector Seal Kit. AP0002
Old Nov 21, 2011 | 08:40 PM
dukie1877's Avatar
dukie1877
Thank you Mark
Old Nov 21, 2011 | 08:48 PM
bismic's Avatar
bismic
Thank you Mark
Let me slightly correct myself - I have been told by folks I trust (several) that the International and/or Motorcraft part numbers quoted above will not include the needed d-rings. I know that the Alliant Power kit does have them. Sean's (amdriven2liv) link to Oregon Fuel Injection makes it sound like they do include them .
btw - thanks for the reps!
Old Nov 21, 2011 | 08:50 PM
dukie1877's Avatar
dukie1877
The kit ford sells does not include them im 100% sure I talked to 3 different parts guys at 3 different dealerships and they cant even get the D-rings. I bought the seal kits from ford when I had my injectors out. Sure wish they would include these could save allot of people a ton of time.
Old Nov 22, 2011 | 02:54 AM
npccpartsman's Avatar
npccpartsman
Ford 3C3Z9229AA
3C3Z9229AA (Ford part #) = CM5055 (Motorcraft #) = 1843682C91 (IH #)
None of these have the "D" ring. They have a black o-ring (upper), white o-ring (lower), blue o-ring (injector connector), and copper crush washer. The Alliant Kit (AP0002) is probably only available through their dealer network (like Oregon Fuel Injection).
Old Nov 22, 2011 | 03:48 AM
dukie1877's Avatar
dukie1877
Thank you NPCC but I found the leak I should say I found a leak hopefully its only the one. The flex line that comes out of the oil rail on the passenger side was broken off inside the oil rail. Im going to try and find a new one. Any parts number for this lol?
Old Nov 22, 2011 | 04:29 AM
npccpartsman
Bismic or MChan might have it but that's one I don't have, sorry. I will after it's posted though......
Old Nov 22, 2011 | 04:31 AM
dukie1877's Avatar
dukie1877
haha ok thanks. I think it might be f81z9a332aa but im not sure cant seem to find a picture.
Old Nov 22, 2011 | 08:45 AM
BLADE35's Avatar
BLADE35
thats it you Found it good job I bet the truck will start now once you get that line fixed never heard of one breaking there
Old Nov 22, 2011 | 09:10 AM
dukie1877's Avatar
dukie1877
yes sir I hope so. Might not have to strap the elk to the mercedes after all if im lucky haha. ill post a pic of it later
HTM101
Dec 1, 2018 11:53 PM
78fordman
Oct 30, 2015 06:08 PM
dukie1877
Oct 14, 2011 09:54 AM
deere55
Jan 8, 2011 05:55 PM
parrisw
24
Nov 27, 2008 08:42 PM
