For some reason, FTE will not let me post the photos of the shifter. How about sending me a PM with your email addresses so I can send them directly to you.
If you go back can you keep an eye out for that bar that goes from the shifter you got for me back to the transfercase? You can't buy them new anymore. Greystreak said he had one for me, but he's been away for a couple of days and I haven't heard from him (probably just busy so not complaining). It can be from any 92-96 f150, f250, f350, Bronco; as long as it has the E40D auto transmission. You can tell the E40D from the other auto's by it's unusually long pan that is stamped "Metric". It also has the overdrive cancel switch on the column shifter. The bar in question should also be stamped "E40D" or something very similar (maybe abbreviated). If I hear from Grey or find another source in the meantime i'll post again and cancel the request.
